#11 |
Hi guys, thanks to all!!!
This evening i try to see under the 4 & 6 pulg and the stud/nut is very dirty by oil. I'm sure that the leak is that... This stud is in a very very bad position...how i can work well without remove the engine??? ;-) I must remove the plastic fender?Someone already do it??? Thanks in advance!!!!! Max |
#12 | |
You should remove the inner wheel panel and get to the stud. Or possibly from underneath. Having headers makes it easier. Pete or Lee could provide a better description. Pretty sure that's what it was. Ci sentiamo, Dominic |
#13 |
Hi Dom,
how are you???? ok..i'll try during the week wnd to do something. From underneath i think is most difficult. I'll try to remove the inner wheel panel... After remove the stud i must degrease it and put the loctite before put it in his hole? Thanks in advance!!! Bye |
#14 |
Massimo,
Si primo di metendolo nel bucco, bisogno a lubricarlo bene cosi scivola quando entre! Domanda a Pete. Lui sa ezzatamente come si fa. ![]() |
#15 |
![]() Join Date: Dec 2003
Dominic deve pensare Pete il greco non parla italiano. LOL
#16 |
#17 |
ahahahahahahahahahaha
Dom, scritto cosi' sembra che nel buco devo mettere qualche antra cosa!!!! :-) Ciao A26B, hai anche tu origini italiane??? |
#18 |
#19 | |
Sì, sto facendo scherzi greci con pete!
#20 | |
Bè...complimenti, scrivi benissimo in italiano...comunque sia il buco è buco!!!! Scherzi a parte se ho tempo domani provo a stringere il dado e vi sapro' dire!! Tomorrow if I have time I try to tighten the nut and will let you know what happens Thanks guys!!! Max |
