Old 08-13-2013   #11
scottfab
scottfab's Avatar
Default Re: Stranded.Is it VATS?
Here is another write-up. This one by Mark H.
http://www.zr1netregistry.com/Inform...ont-Crank.aspx
And a diagram showing the clutch switch etc....
Scott
Old 08-13-2013   #12
scottfab
scottfab's Avatar
Sorry this happened to you. It is a sickening feeling for sure.
Before you pull the engine or starter or wire up to any nuclear power source just check the clutch switch as has been mentioned. Make sure it's the clutch switch you look at (temp jumper across) as there are others down there.
I've got 90k on mine. The only no starts I've ever had are when I washed the engine (as a novice) and when the fuel pump went out.
I have a 90 and as such the clutch switch is susceptible to arcing. Therefore, I always fully depress the clutch before turning the key. I also readjusted the position of the switch to make sure it fully depresses when the clutch peddle is pushed.
FYI
Here is a nice write-up on "no start"
Scott
Old 08-13-2013   #13
Dave2
Hello
If your security warning light works on the dash, VATS probably isn't it. I just went thru it on my car. My CCM croaked shutting down VATS, security light- indicator on dash, interior lights, and ability to start- though fuel injection pump continued to work. Rebuilt CCM $280, and a lot of work to R&R
Dave2 is offline   Reply With Quote
Old 08-13-2013   #14
Mitsumark
Ok guys.Im on site.I am attempting to jump the clutch switch under the dash.I only see one harness with a thick solid yellow wire and a thick solid purple wire on the male end.The female it plugs into has 2 thick black wires coming out of it..Where is the safety switch?
Mitsumark is offline   Reply With Quote
Old 08-13-2013   #15
Location of Clutch Safety Switch by TomC'Crabs
The clutch safety switch is up on the clutch arm.
You will have to remove the hush panel to get at it.
It's fairly easy to jumper the switch, all you need is some wire and a couple of alligator clips.
Try holding the key in the START position while engaging and dis-engaging the clutch. Carefully watch the amp gauge. Normally, when the clutch safety switch is engaged the amps drop as the connection is made to the starter.
Some people report having success with giving the starter a wack with a long rod or a socket extension.
I've never done it, but I've read that there's one place where there's room between the runners on the plenum to get access to the starter.
TomC
'Crabs
Good Luck
Cliff
Old 08-13-2013   #16
Mitsumark
I removed the hush panel if the one your speaking of is the carpeted and plastic panel facing the floor..I see switches on the top of the pedal assembly.However none of them have purple or yellow wires..What am I missing?Anyone have an actual pic?I cant read wiring diagrams as Im on a tiny Iphone.If Im looking at the clutch pedal adjustment screw,is the switch above or below that?
Old 08-13-2013   #17
Look for a connector about the size of a matchbox....also would be good to relplace the relays lined up under the dash
http://www.zr1.net/forum/showthread.php?t=20411&page=2
Old 08-13-2013   #18
Mitsumark
That harness hes holding in his hand is the one I found.It has a solid purple and solid yellow..Very thick wires.NO STRIPES....I jumped the pins together on the male side and it still wont start,
Old 08-13-2013   #19
There are three relays under the D/s dash, try replacing them one at a time and then starting the car, I am trying to remember which one is the starter relay, that was my issue
Old 08-13-2013   #20
Mitsumark
Where exactly is the purple starter wire that ALZR1 was speaking of..He said something about it being near the ECM..I can try to jump the starter but want to make sure I have the right wire,
