#11 |
YikES! 94 pages DataMaster User's Guide .pdf !
![]() Can't print THAT out, and can't read the laptop in the 'library', where my throne has a hole in the middle ![]() |
#12 |
OK - how long should a recording be (in order to not create a ridiculous LONG file for posting here), should I make???
And only in Closed Loop, I guess? And should it be a 'Road Test' for better diagnostic data??? FIRST thing I'm looking for is the Cruise Control problem, of the 2 MPH swing...... |
#13 |
![]() Join Date: May 2013
Schrade,
It shouldn't take too long to gather the data needed. I think you said that it doesn't sag when you ease into it from idle but does when you romp on it. Does it do it all the time, for ex. in open loop mode while warming up or only in closed loop after warmup? That might help you to decide how long a test. |
#14 | |
After TPS exceeds 'X' position, in it's range of motion, in each gear, it's smooth as glass TPS response... If I can't get soon from TTS DM how to initiate a scan, I'll just post another vid that might reveal something here... and thanks for helpin' again there Franke... You picking up anything here? When you help, and THINK, on another's problem, you can sometimes learn something yourself - not necessarily about THAT problem, but just HOW TO think problems out!!! This one is diggin' on me - that's for SURE!!! WHY CAN I HOLD A STEADY HIGHWAY SPEED WITH THE MECHANICAL LINKAGE, BUT CRUISE CONTROL CANNOT. IT SWINGS 2MPH. AND AT LOW THROTTLE POSITION, THERE'S 'UNSTEADINESS - SAG' JUST AS PEDAL COMES OFF 0% THROTTLE??? ??? Last edited by Schrade; 08-06-2013 at 09:34 PM. |
#15 |
Sounds like 2 problems. MAP sensor voltage varies with intake manifold vacuum. The MAP can be tested on the car or off with a vacuum pump and voltmeter as per the FSM. When slow pedal - multiple things are happening. Voltage starts changing in the TPS to the ECM and Manifold vacuum starts dropping back toward atmospheric pressure changing the MAP voltage to the ECM. Possibly since everything goes to and from the ECM, did you try another ECM? I'm runnin' out of ideas here.
Cruise uses electrical, vacuum and mechanical links. I think the Cruise issue is a seperate problem. Section 9B in the FSM describes its operation but is not a lot of help. One thing I think they do have in common possibly is a vacuum leak. Did you verify all hoses and canisters integrity etc? I once worked on a ford that had a vacuum problem that had a hose with a small crack in it. You couldn't see the crack visually and I found it by using a vacuum pump on the hose alone. Boy was I surprised when the hose couldn't hold vacuum even though it looked good. |
#16 | ||
I'm the guru of vac leak detection, but the process doesn't apply to LT5
(and I don't even HAVE a loping idle) Quote:
