Old 08-03-2013   #11
Schrade
Default Re: Driver for datalog hardware...
Thanks for helpin' here Franke - appreciate it much! Sure wouldn't mind if a few others chimed in too...
I got some 'data', but it means nothing to me just yet here.
Started a recording with the engine off, then started the engine, and noted parameters doing 'reads', then played with the throttle, noted additional reads, and shutdown.
Saved files don't read in 'progression'. Have to play with it tomorrow some more here...
Old 08-03-2013   #12
Franke
Schrade,
When I had O2 and injector problems the histogram file showed me the lean and rich issues I was having by left or right side. Its part of block learn mode and you can get a lot of info from this. Do you have the datamaster manual? You can down load it to explain all of the parameters of the program. It was quite a bit of help to me.
I was going to try Tuner Pro as well but since I cured my Z's problems I didn't go that far.
Are you having any issues or just experimenting?
Old 08-03-2013   #13
Schrade
No issues - with exception of the 'off idle sag' / slow-retarded throttle response. Trying to see if voltages for MAP or TPS show irregularities or out of spec there...
Will see if TunerPro is more user-friendly to navigate tomorrow here.
