Old 08-05-2013   #11
Default Re: Flat Plane Crank
Apparently balance shafts are needed to run a flat plane...
Old 08-05-2013   #12
efnfast
So, I'm learning something new. Never heard of a flat plane crank.
I've read the benefits are you can fire LRLRLRLR, or the reverse - odd-even ect. HOWEVER, according to Wikipedia, the fireing order of the Coyote is LLRRRLLR???
Old 08-05-2013   #13
Sounds like more trouble than its worth depending on application.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 08-05-2013   #14
efnfast
Seems like an awful lot of work for 15 hp.
Old 08-05-2013   #15
Ferrari uses Flat Plane Cranks on all its Supercars....I think its worth alittle more than 15hp....move F1s run a flat crank.
Old 08-05-2013   #16
Looks like they got 659hp from a 6 liter LT-5
Old 08-05-2013   #17
efnfast
So that's about a 360CI. What have we (really I mean you guys) gotten from our LT-5's at 6 liters?
Old 08-05-2013   #18
I think you could get 560 or so out of a 368(keep in mind you might need a 2K idle for that Lotus GT-1)
Old 08-05-2013   #19
efnfast
So, you think you could get about 100 hp from this crank?
How come I find the Coyote to have such a stange firing order? Seems that's where most of the hp comes from.
Old 08-05-2013   #20
Polo-1
I think I heard Loco just 480rwhp out of his 368 with stock cams. That's about 550ish crank, right. Put in a set Pete cams, I think you would be knocking on the door 600ish.
