#11 |
![]() Join Date: Feb 2011
It could be, but it would probably cost too much since the siphon transfusion method does waste some percentage of the new fluid. Brake reservoirs are pretty big if you think about it. A conventional bleed is best since it purges the calipers of older fluid.
#12 |
Yeah that's what i'll do, bought a case of Motul.
#13 |
![]() Join Date: Nov 2007
Squeal?? I'm still
![]() Sorry to be so obtuse. ![]() |
#14 |
Just a thought:
Maybe the best way to purge the clutch system is to remove the slave cylinder, open the bleeder valve, and force the actuator rod into the cylinder. This will instantly purge about 90%+ the contents of the cylinder - where the contaminated fluid resides. Then, placing a finger over the bleeder valve, and allowing the slave piston/actuator to relax will pull fresh fluid into the slave without introducing air into the system, if done carefully to avoid it. I don't recall if the exhaust has to be removed to access the slave - but if the exhaust manifold is removed, e.g., to do a header install, that would be an excellent time to purge the clutch system. After that, normal maintenance is all that is needed. Saves a LOT of time and wasted fluid that way! |
