07-23-2013 | #11 | ||
Re: TPS response...
And the answer is, "Not necessarily does it mean the pot is linear." It means - that IF my TPS sensor works properly, then what I drew as conclusion before, is correct: Quote:
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 07-24-2013 at 12:21 AM. |
07-24-2013 | #12 |
Re: TPS response...
Seems like many Dodge diesels have problems that are fixed with 'Linear-Taper Potentiometers' installed in the TPS.
Hmm...
07-26-2013 | #13 | |
Re: TPS response...
This appears to be the case... , again, IF my TPS is in order:
Or if someone would take 10 and replicate the measurement. ed.: The latter assumption is NOT correct, after observing a STEADY voltage increase, with everything plugged back in . edit: Throttle response is in sync with the potentiometer, NOT the voltage reading, which SEEMS linear, after observation. This is eatin' me up here.
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 07-26-2013 at 01:48 PM. |
07-26-2013 | #14 |
Re: TPS response...
Just got off the phone with Marc. He was at the bench, and did the impedance test.
First time, he said NON-linear. Baseline 6,740 (units?); pegged 1,000, midway range of motion 4,220. His cell cut off, he called back post 5 minutes. "It's linear - I did some calculations", he said. Do my snappics in the other thread look linear? Isn't the 'halfway sweep' reading that I posted AT LEAST HALFWAY??? We gonna' have to rig an arm extension of some sort, and get more reliable readings... Might be moot however... The original problem of 'off-idle sag', is attributable to the collapsed MAP sensor hose (yet to check)... No one mentioned that collapsed MAP vac hose would make for this 'off-idle sag'???
07-26-2013 | #15 |
Re: TPS response...
Hi Schrade,
Somewhere in these two posts I thought I mentioned MAP and possibly fuel delivery but I can't find that post. Based on those above readings I can't figure it out. If the pots overall resistance is 6740? and midway is 4220 with WOT at 1000 ohms it would seem to me to be Logarithmic. Oh well. Iffan you do find the sag please post as it will undoubtly help others. |
07-26-2013 | #16 | |
Re: TPS response...
I missed your MAP issue post , being a possible cause of this sag in TPS response. Thanks! I sure wish we could get somefeedback on this; everyone knows mods, but when it comes to common issues, or basic tune, either no one posts up, or no one knows ...
07-26-2013 | #17 |
Re: TPS response...
By the way I did have a MAP sensor go bad on my Z. The car went nuts until the ECM took over and used a calibrated setting for MAP until I could get her home. I had very little throttle response and stalling. Some idle and then stalling (had to keep the rpms up but even then it was tough) until the ECM learned the issue.
07-26-2013 | #18 | |
Re: TPS response...
Knowledge is good. Sharing it is better yUP!!!
12-09-2013 | #19 |
Re: TPS response...
So if I have a MAP response issue, it would show up in DataMaster, in a slow RPM increase, as an erratic change?
