Old 07-17-2013   #11
USAFPILOT
USAFPILOT's Avatar
Default Re: Old Blue Upgrades.
3.73 will keep you from having to shift into 4th at the traps.
Old 07-18-2013   #12
Hog
Might as well go 4.56 then. 6500rpm is 110mph in 4th 7000 is 119mph in 4th. And 5th gear gives you 160mph at 7000rpm
Old 07-18-2013   #13
Originally Posted by We Gone View Post
Well its time for some upgrades. Old Blue now has 53K miles so I've decided to take a drive up to Marc's (date set for 1st week in Aug). So far this is what I have. Just want to review with you guys that have had mods done to see if I am missing anything. Not a track car and do not run 1/4 mile just a few road trips a year and car shows.
Thanks Steve
510 HP Engine Upgrade Package
Refinish the engine in silver or Met silver color?? not sure if anyone can post pics of them would be great.
Black lettering and red numbers option.
Stainless steel socket drive engine top bolts.
Install modern fuel injectors.
Install a new thermostat
Install a supplied water pump
New accessory drive belt
Install a Dana 3.73 rear axle gear set.
Clutch disk
Change A/C to R134
Hi Steve--
I did essentially the same thing last year with Marc. I did the 510 package (but minus the Fidanza and I added Cats, so actually a 486 for the moment). I did Fine Silver with black bolts that were left over from other redos. Looks more stock, although I did add Haibeck lettering. Last year I did the 4.10s--I have had them on my 93 for 13 years and they are the best upgrade you can do for street driving. My opinion: don't spend the money on only 3.73s. Also added Corsa and Hurst short shifter as I had on my 93. There are a number of pictures in my albums section but her are a couple:
Old 07-18-2013   #14
USAFPILOT
USAFPILOT's Avatar
does anyone with 4.10's use first gear at all?
Old 07-18-2013   #15
Jagdpanzer
Jagdpanzer's Avatar
all the time
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-18-2013   #16
RHanselman
RHanselman's Avatar
Yep... Even in the Twin Turbo...
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
RHanselman is offline   Reply With Quote
Old 07-18-2013   #17
Yes Always
Old 07-18-2013   #18
RICKYRJ1
RICKYRJ1's Avatar
I have 3:73's but will probably upgrade to 4:10 one day. I run 19" rear tires so the gear gets reduced. I have driven Phil's car with the 4:10 and loved it
Old 07-18-2013   #19
Fully Vetted
Fully Vetted's Avatar
Since he doesn't drag race his car that won't matter. It's more about making it fun on the street. I think you would love the 4.10's. Plus, 1st is still usable (useless with 4.56 on the street) and you can still milk some mileage out of the car on road trips.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 07-19-2013   #20
USAFPILOT
USAFPILOT's Avatar
I think I will do the 4.10's if I do gears, I hear they put the most HP down.
