Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > Cleaning and Waxing
Old 02-09-2014   #11
cadillac531
cadillac531's Avatar
Default Re: Iron/'Hard' water spots on finish.....
Originally Posted by scottfab View Post
Some of this is plagiarized but modified by my own experience.
Step 1
Wash the car thoroughly. This will remove road grime and dust on your car. It will also help eliminate some of the minerals responsible for the hard water spots. As always, wash in a shaded location - never in direct sunlight. While the products we are going to use are completely safe to use, heat from a hot surface or direct sunlight can turn something harmless like car soap into an amplified cleaner which can yield unknown results. So while vinegar is completely safe to use on your car's surface, using it in hot sun should be avoided. Now dry the car completely.
Step 2
Mix a 1:1 solution of regular white vinegar with distilled water. Regular tap water will work fine. Apply the vinegar/water solution with a spray bottle on to the affected paint finish. Allow mixture to work for up to 10 minutes. The acid in the vinegar will help loosen the hard water minerals embedded in the paint. This is similar to running your coffee maker with vinegar to remove the build up of hard water.
After allowing to work for 10 minutes, wash and dry the area again to remove the water/vinegar solution. The minerals from the hard water will be gone at this point but you may still notice the rings. If so, repeat. The key is to dry the car quickly.
Step 3
Wax several times. Nothing fights water spots better than some preventative measures (wax)
This is great information. Thanks, Scott.
Constantine
Registry Founding Member #0235
1991 Corvette ZR-1 -- Stock, 94 ZR-1 exhaust system, muffler delete.
1956 Chevrolet Belair -- Pro Street, 531ci Cadillac, 8-71 Blower, 8pt roll bar, built TH-400, 9" rear, 1,100 HP -- Street Car.
https://www.youtube.com/watch?v=z8y4cwcvK0s
1968 Mustang "Pegasus" -- Zeeker Chassis, 584ci Dart Block, Brodix Big Brodies, 2-1150 Dominators, FTI 'Glide, 1168 hp, best ET & Trap(holding back) 8.57@159 -- 7.9X -- 1/4 mile car.
1970 Chevelle -- 468ci, TKO600, shaved and smoothed everything.
cadillac531 is offline   Reply With Quote
Old 02-11-2014   #12
cvette98pacecar
Step 1
Step 2
Step 3
Scott, I could not have said it any better.
I would add a water filtration kit that will remove the high iron content from the water. Here is the filter that I use.
http://www.zymol.com/zymolreineswate...ionsystem.aspx
Robert J. DeMarco
[SIGPIC][/SIGPIC]
NCM Lifetime Member #2655
Pacecar Registry Member
1991 Shinoda Aerobody Spyder,
1998 Pace Car
Old 03-01-2014   #13
Step 1
Step 2
Step 3
x3
Water spots on my black 95 were cleaned right off with the 50/50 mix of white vinegar and (distilled) water.
I use a (nano) polymer polish instead of wax, which I'm convinced was part of the reason the spots were so easy to remove. The car did get a redoux coating afterward, in case the vinegar removed the polymer polish.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
