Old 12-03-2013   #11
Default Re: FS: Delphi 26lb fuel injectors
Originally Posted by randy ransome View Post
I have a 368 cubic inch, Cory Henderson built, with a 63mm throttle body.
Stock cams, just wondering if these injectors will be too big?
I'm assuming Corey tuned the motor as well and he's one of the best. The real issue w larger injectors involves control of the PW at idle. Too big an injector and a smooth idle becomes problematic.
There are big displacement motors running on stock injectors although that doesn't mean they couldn't use more fuel. A determining factor is assessing the injector duty cycle at WOT. Is the injector going "static" in order to provide the proper amount of fuel at WOT?
Rule of thumb is you'd like to be at ~85% duty cycle.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 12-03-2013   #12
randy ransome
randy ransome's Avatar
I got ya. Yea, I'll just order the replacements from FIC.
Idling problems are what I'm having. Thanks.
randy ransome is offline   Reply With Quote
Old 12-03-2013   #13
tpepmeie
There is NO risk of idle control with 26 lbers. At idle, the entire pulsewidth is sent to the primary injectors. This is likely well over 4msec, so not even close to the non-linear portion of the injector curve.
If the calibration is modified for 26lb injectors, you will notice no adverse affects.
Old 10-19-2014   #14
tpepmeie
Bump TTT. Need these gone. Make offer.
Old 10-20-2014   #15
Pete
Pete's Avatar
Todd,timing timing timing is everything we just went with bigger injectors on one of the big inch FBI Z's.
If tuned for these injectors idle will be fine,LT4's came with 28lb injectors or were they 26lb either way they idled fine.
GLWS
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 03-11-2015   #16
tpepmeie
bump. Nobody needs a nearly new set of stainless injectors for $200. Thought these would go a lot sooner.
Old 03-11-2015   #17
Todd,
Is this what you used for the 427? If so, any sense of what the duty cycle was at WOT?
Old 03-11-2015   #18
tpepmeie
Todd,
Dom,
yes, these were used in Build 1 of the 427. I think they were around 63% DC per the math. 24ms pulse width x .51 (secondary scalar) = 12.2ms per injector. The datalog I have from the chassis dyno stopped at 6200 rpm.
I don't have the datalog from the engine dyno. But I can say that we were running 12:1 at 7000 rpm/700 chp, but with ridiculously high VE table values. Translated-- I think other components were limiting the fuel delivery, not the injectors.
These injectors *should* be good for:
750 chp @ 80% DC
650 chp @ 70% DC
high 670's was the uncorrected hp from the engine dyno on that day with those atmospheric condition. So, I'd say the DC was in the low 70% range at peak power on that day.
Old 03-11-2015   #19
Jagdpanzer
Jagdpanzer's Avatar
Todd,
PM sent
Are both primary and secondary injector tips the same stlye as used in the later 93-95 engines?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-11-2015   #20
tpepmeie
yes, later style tips.
