#11 |
![]() Join Date: Dec 2007
Had the same issue. Replace sending unit and all is fine now.
#12 |
![]() Join Date: Apr 2013
Well I started it up this morning and it went up to like 60psi at idle. Thinking that if there were an issue internally bad enough to create 0 on the gauge it wouldn't read 60. Gonna see if Jerry has a new sensor...
#13 |
![]() Join Date: Nov 2007
Sounds like it could be the sender. And, then again, the dash instrument cluster board contacts have been known to get "frosty" (read: oxidized), requiring some cleaning and some contact cleaner spray.
I agree w/ others on the sender, and I'd begin with the sender. It is easy to replace, and more likely the culprit, from my experience with senders (in general), especially with a car that has sat for extended periods (as I'd guess yours has seen some extended periods with little running). p. |
#14 | |
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 07-14-2013 at 09:08 AM. |
#15 |
![]() Join Date: Dec 2003
I'm out right now, presently sourcing in AC-Delco for stock.
In the meantime, try this for a source local to you. http://www.oreillyauto.com/site/c/se...tte&vi=1041297
#16 |
Cool - thanks guys! I will clean the contacts and see what happens. Then I will see about getting one. Nice to know that it isn't an internal engine problem....
#17 |
UPDATE: I ordered the sending unit from Jerry's, replaced yesterday. Seems to read MUCH better now. It is a 5 minute fix just to let those who may have oil gauge problems know.
