Old 07-12-2013   #11
2ZR1S
2ZR1S's Avatar
Default Re: Finally completed coilover and sway bar install, plus Christmas came early
Looks great. I drove my 92 today, these cars are a blast. Let us know how you do at the track.
Jon R. Member #490
1992 ZR-1 Arctic White/Red
2008 Z51 Silver 6 spd (Daily driver)
2ZR1S is offline   Reply With Quote
Old 07-13-2013   #12
cvette98pacecar
Originally Posted by CJ_ZR1 View Post
Thanks for the kind words guys
Robert, I am trying to work it in. Guessing your going to make the trip down?
It is almost 1200 miles, I am trying to work it into my schedule.
Robert J. DeMarco
[SIGPIC][/SIGPIC]
NCM Lifetime Member #2655
Pacecar Registry Member
1991 Shinoda Aerobody Spyder,
1998 Pace Car
Old 07-13-2013   #13
Blue Flame Restorations
Cj, love the CCW's. You finally made the car your own. Great job and it looks fantastic. =D>
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 07-13-2013   #14
rudolph schenker
rudolph schenker's Avatar
Look great!!!
1994 ZR-1 Admiral blue/beige #67
rudolph schenker is offline   Reply With Quote
Old 07-13-2013   #15
KGV
KGV's Avatar
Hi,
The car looks very good. Is it the coilovers or the new rims that reduced the gap between the top of the wheel and the fender? Also, do you have any issues with tire clearance; turn lock to lock, etc?
Thanks,
Ken
KGV is offline   Reply With Quote
Old 07-13-2013   #16
Hog
Finally 18's that look great on a ZR-1. Those front look BEAFY from the top/engine view.
Good stuff.
KGV-I assume the coilovers adjusted the ride height, rim selection would o nothing to wheelwell gap unless taller tires were added
peace
Paul
Old 07-15-2013   #17
HAWAIIZR-1's Avatar
Awesome and thanks for sharing. I love classic CCWs too and can't wait to get my coilovers on.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 07-15-2013   #18
rkreigh
toyo ra-1s are one of my favorite tires and your car looks fantastic with the ccws
carter should be able to hook you up on center caps or know what would work
what spring rates did you go with? let me know how you like the ride and handling
like the zr-1 on the side too, very unique!
95 390 LPE ZR1 (505 rwhp)
Old 07-16-2013   #19
carter200
carter200's Avatar
"Carter should be able to hook you up on center caps"
Yes, I can. PM me and we'll talk......
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 07-17-2013   #20
CJ_ZR1
It's actually both. Car is a lot lower than stock using coilovers and the 18" rims/tires are almost a full inch more taller than the 17" A-molds with tires. No clearance issues except I can no longer turn wheel lock to lock. The front sway bar has to be relocated forward about an inch to clear coilovers and because of the 11" wide front rims I can only turn 3/4's each way. Not bad on the road but does make for 8 point turns in parking lots.
Spring rates are 425 front and 275 rear. Love the way the car handles and rides with the larger sway bars and coilovers. Car stays flat and is very responsive.
CJ Daniel
[B]1991[/B] ZR-1 #834 [COLOR=royalblue][B]Steel Blue Metallic/Steel Blue[/B][/COLOR]
[COLOR=red]Frank Approved ZR-1[/COLOR]
[SIZE=1]- Ported air horn, throttle body, plenum and injector housings (Tommy Morrison)[/SIZE]
[SIZE=1]- FIC SS Injectors / Nology hot wires / Screemin Deamin coils[/SIZE]
[SIZE=1]- Fluidyne aluminum radiator and 9 row aluminum oil cooler[/SIZE]
[SIZE=1]- 4.10 gears / Fidanza light weight flywheel / Hurst short throw shifter[/SIZE]
[SIZE=1]- Stainless Works long tube headers / Borla exhaust with x-pipe[/SIZE]
[SIZE=1]- DRM Coilovers / 32mm front 26mm rear sway bars[/SIZE]
[SIZE=1]- ASM bolt in 4 point roll bar[/SIZE]
[SIZE=1]- 93 ZR-1 Sawblades[/SIZE]
CJ_ZR1 is offline   Reply With Quote
