06-17-2013 | #11 |
Re: Secondary Actuators, Upside down or Not
Ideally, if the actuator arm was a rod, connected straight through the center of the diaphram and perfectly aligned with the linkage bellcrank, then there would be no controversy, but it's not.
As it is, the actuator arm is an "L" bar and the linkage arm is offset from its connection at the center of the diaphram. when the actuator arm is aligned with the bellcrank, the center of the actuator diaphram is not aligned. As such, the pull is angular when vacuum is applied to the actuator. As Bearly Flying observed, when the arm is "angled" to the bellcrank, the center of the actuator diaphram is in alignment and the pull is straight when vacuum is applied to the actuator. When the actuator is installed with the linkage arm "straight," you can see the diaphram move angular in the housing as vacuum is applied. This is evidenced by the need to grind & remove metal from the arm to clear the actuator housing when vacuum is applied. Scott, Your analysis would be correct IF the linkage arm fitment to the bellcrank shaft was such that it forced the arm to remain perpendicular to the bellcrank attachment pin. It is not however, as it fits loosely enough that it works more like a flexible ball chain than a connecting rod. On my 60K mile 94, I tested the actuators as they were installed "angular" and reversed "straight." "Angular" operated smoothly and quickly, "straight" was jerky & took slightly more vacuum to open fully. I consider Gorden Killebrew a good friend and a true genius on the C4 Corvette from bumper to bumper, but he was responsible for propagating the "installed backwards at the factory" myth. He is incorrect in this assumption. The angular linkage arm does look "wrong" but in reality it is not installed upside down and it works perfectly in that configuration. Most importantly, it was purposely designed & installed that way.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 06-17-2013 at 10:20 AM. |
06-17-2013 | #12 | ||||||||
It simply makes contact with the side of the actuator regardless of the angle. Quote:
Also the perfect L has to be altered to a more acute angle when the actuator is installed right side up (so pull is straight looking) This puts the top of the L in alignment with the center of the diaphragm. (THIS IS THE KEY POINT) I must admit I forgot about this bend until now. I remember bending a part but could not remember which. Quote:
I do agree is was purposely installed that way. I do not agree it was designed that way. I think it was left that way. Lack of time or ? to do a proper fix. In summary: This discussion has brought back to memory the step by step approach I took in resolving what at the time, seemed to be an assembly error. Little did I know at the time that the fix I made would lead to: 1. 10yrs of reliabiliy 2. aesthetically NOT upsetting appearance that will confound future owners. I recommend that everyone leave the actuator looking crooked (upside down) unless you are willing to at least bend the L bracket such that the top end of the L be aligned with the center of the diaphragm. If you do so you'll have a visually pleasing appearance AND reliable operation.
06-17-2013 | #13 | |
I (because I am a Pirate) install the canisters with straight link back to the pivot linkage. I file the canister link arm if I notice it is even close to touching the canister opening. I install the link straight back to eliminate any sidewase thrust on that little link keeper on the pivot linkage shaft. That is the Pirates way Cliff 1990 LT5 1991 LT5
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-17-2013 at 05:43 PM. |
06-17-2013 | #14 |
Here is a diagram to better show how the straight pull is accomplished
by bending the L bracket after putting the actuator in right side up.. Note as so many have noted (not just Gordon Killebrew) the upside down actuators are visually upsetting. The bent L bracket is less so as well as fixing the problem of hitting the end of the travel on the ball socket.
06-17-2013 | #15 |
Scott, if you're happy, I'm happy and I will respect your EE skills and hope you can respect the ME skills which are a portion of my PE skills.
Out of respect for a significant volume of empirical data (6,000+ LT5 engines with "angled" actuator arms) the angled actuator arms work just fine. if the "angled arm" visually bugs anyone, then by all means, rotate the actuator, increase the right angle on the linkage arm to an acute angle but don't forget to straighten it at the end so it is perpendicular to the bellcrank pin. BTW, there is no ball socket at the attachment to the bellcrank.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 06-17-2013 at 12:47 PM. |
06-17-2013 | #16 | |||
The upside down actuators work but they are problematic both visually and functionally (end of throw binding) As with other design issues on the car. They can be and have been improved (fixed) by many of us. Quote:
A bellcrank is composed of several components. the L bracket connects to the bellcrank through a "king pin" or "ball socket". A bellcrank is the arm part. On many bellcranks there is a shaft connection point. In our cars a king pin is used at the "moving pivot" point. See this figure for info: http://myweb.tiscali.co.uk/technologyweb/bellcrank.gif This is all getting off topic so I think we're beating a dead horse. Suffice it to say there are reliability issues with the 6000 plus cars with secondaries that work so well with the actuators "purposely" installed upside down. To fix the original design flaws there are those feed up with the reliability of the secondary system so much so that they rip them out. Not that even a major component of these failures are at the actuator but I submit that it contributes to this reliability issue. In so far that that is true I offer the correction to the weird looking upside down issue for the betterment of the car and it's survival. I'm now done with this thread. I must need something at the store. It's nice out and I need to go see if my secondary actuators still work ok.
Scott Vett owner since 1979._It's about the car and the people Last edited by scottfab; 06-17-2013 at 03:50 PM. |
06-17-2013 | #17 |
I'd suggest ripping them out.....no more troubles...
1988 KOH Prototype EX5023 sold 1990 ZR-1 #444 Convertible 1990 ZR-1 Black #966 1991 ZR-1 Quazar Blue #296 1957 Duntov SS Project Last edited by Blue Flame Restorations; 06-17-2013 at 04:28 PM. |
06-17-2013 | #18 |
Yes, I have read several of the threads on that. Still haven't came to a conclusion on that subject.
91 ZR-1 Arctic White/Gray 01 C-5 Magnetic Red/Black 85 FJ 1100 (Big Bore kit, Hooligan Bike) 05 FJR 1300 Yamaha (Long Distance, Sport Touring) And a whole whack of RC Planes |
06-17-2013 | #19 |
For me, it made perfect sense. Less parts to fail and less vac lines to leak. I've never looked back....
06-17-2013 | #20 | |
1990 LT5 with Secondaries (Non Kludged) 1991 LT5 No Secondaries (Kludged)
