#11 |
![]() Join Date: Oct 2004
Tyler you of course are correct but some/most will do it as directed and also get a short education of WHY it's there, for the several years I've posted it that way and for the reason I stated only two have commented about it, yourself and a very good friend from the service who is a professional truck driver. My comment isn't/wasn't intended for only the C4 Corvette but anything with the clutch operated safety switch. The quick surge forward or rearward if done "my way" and if it doesn't start is very educational, VERY! Most mowing machines come to mind for PTO safety when I think of clutch safety devices and many PTO's are bypassed also.
#12 | |
![]() Join Date: Jan 2009
Look at the next "no start" as an opportunity to isolate and find the root cause. Here are a few links for more background on "No Start" things: http://www.zr1netregistry.com/Inform...art-issue.aspx http://www.zr1netregistry.com/Inform...ont-Crank.aspx
#13 |
#14 |
![]() Join Date: May 2008
I had a similar issue with my '92 ZR-1, three years ago. When the car got hot (Up to temperature) and I parked it, it would not start again, right away. If it sat for a while, long enough to reelly cool down, it would start again. We ended up replacing the starter and all was well.
Joe Thomas Corvette Club of Michigan NCRS-Michigan Chapter Member NCM Master Ambassador NCM Lifetime Member Former NCM Board Member 1991 ZR-1 Melon Copper Metallic/Black 1992 ZR-1 Bright Red/Black (Sold) 1995 ZR-1 Bright Aqua/Gray (Sold) 2012 ZR1 Super Sonic Blue / Dark Titanium |
#15 | |
![]() I installed your Relay, Differential Drain plug, Eliminated TB Coolant and Air Induction, and Added Belt Tensioner Billet Aluminum Pulley as standard corrective measures to what GM started on both a 90' and 91' ZR1 ![]() Thanks Crabs ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-11-2013 at 09:39 PM. |
#16 | |
![]() ![]() Join Date: Feb 2010
Nice input, Tom ![]()
#17 |
#18 | |
Obviously, you've never seen me with a schematic. LOL Ask Tyler.... You do great work, tom. ![]()
#19 |
![]() Join Date: Jan 2012
Just FYI,
I thought I was having a clutch switch problem also. When I searched at some of the big parts houses, eg gmpartsdirect, their online catalog showed the switch in stock. I can't verify that as I didn't order one. They may still be available if someone needs one. Of course, you can find used ones too (eg, corvettenutz, etc) |
#20 |
![]() Join Date: Dec 2012
I have recently began having problems with my 91 not starting, altho in my case it seems to be when the engine is cold , it won't start, once the engine is warm, it will start.
Battery tested out OK, I had another battery approx 1 year old I switched into the car, No difference. When I turn the key, I can hear what I believe is the starter solenoid click with the clutch depressed. If I let the clutch out part way, there is nothing, no clicks from the solenoid. So I believe the clutch switch is working properly. The security light does not come on while trying to start the car. So the VAT system shouldn't be at fault. After repeated attempts at hitting the starter, it will engage enough to slightly rock the engine, a couple more cycles of the key and it will generally start normally. I suspect it may be the contacts in the starter itself are arc'ed, but I thought I would check with the Experts to get your thoughts before diving into that Plenum for my first time. |
