06-05-2013 | #11 |
Re: Source for fuel line clamp
06-05-2013 | #12 |
My clamp is broken also. Looks like a common problem.
06-05-2013 | #13 |
Here's what I discovered (with the help of Jep and Marc Haibeck). If that clamp is broken it will allow those fuel lines to shift and move around some. In my case they moved forward and I then had a fuel line resting against the electrical connector for the blower motor. (You can see the connector at the far left of the pic). I caught a wiff of something burning or something hot and thought it was my clutch at first. Then someone said it smelled more electrical. That's when Marc noticed that the fuel line was sitting on top of that connector and actually arcing and burning the insulation around one of the wires. So he scavenged some loom from another location and insulated the fuel line for now.
If your clamp is broken I would definitely keep an eye on it or contact Carter for a new one. He's going to be making me one in the next few weeks so now would be a good time to hit him up about one.
06-05-2013 | #14 | |
Hole in clamp is 1/4 inch with 5/8 inch hole (on bottom of Billet Clamp) recessed 1/16 inch so Billet clamp rests flush on Evaporator Housing mounting base. Billet clamp is then held tight against Evaporator Housing rather than tight on bolt which may or may not be tight in evaporator housing. 87 Octane Billet Clamp tight on top of Evaporator Housing................6 mm bolt..........use 10 mm wrench for nut Base of Fuel Line Bracket on Evaporator Housing....................Billet Clamp is 1-7/8 x 3/4 x 1/2 inch Hole in clamp is 1/4 inch with 5/8 inch recessed hole (on bottom of Billet Clamp). This allows the shoulder of the bolt to sit inside the Billet Clamp.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-05-2013 at 07:12 PM. |
06-05-2013 | #15 |
Cliff,
Thanks for the feedback on the needed part. I won't have the example till th 17th from Fully Vetted. I'll start design/prototyping then. IF anyone is interested please chime in on this post. I do NOT have a price yet but I promise it won't be over $25 shipped. Do not let the price scare you as this was only a guess and WILL probably be way less. This will be a billet 6061 T6 aluminum part worthy of your engine compartment Take care and don't forget to order a anti-fall hood prop key as I want you to be safe and NOT be swallowed by the clam shell
06-05-2013 | #16 |
sure put me down for one
06-05-2013 | #17 |
Always interested in nice new and improved items for my Z Carter! Count me in as being interested
Jim Zorgias 1994 ZR-1 Admiral Blue/Black #245 1996 Callaway Supernatural 450 1990 Callaway Supernatural 490 / CR-1 #7 |
06-05-2013 | #18 |
Jeff and Jim, you are on the list with David A, and Cliff. I promise you'll be proud to have it on your car. It'll be a few weeks till David gets the part to me.
I'll post a firm price and take payment shortly after. Thanks
06-05-2013 | #19 | |
Especially that Oil Filter Cover that actually..........gradually slides down as the air escapes around the oil filter....just changed oil on 90' Z today after a top end I adjusted the position (using a 4 foot long 2 x 4) of the passenger side Injector Housing Coolant Manifold outlet tube just a tad for a perfect fit I was thinking a red Air Duct between the air horn and George Braml SS Air box would be a nice addition to accentuate the Carter Bling Cliff
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-05-2013 at 11:23 PM. |
06-06-2013 | #20 |
Please add me to the list for a new fuel line clamp.
