06-04-2013 | #11 |
Re: Looking for ECC info
Thanks fellas, the list now has 2 more,
16 Coolant Temperature In degrees C 17 Solar Correction 114 = Max light 128 = max dark still missing 19-24 though. It's been rebooted before the light started flashing (had the battery disconnected a couple of times a month ago).
Joe 1990 Bright Red ZR-1 #2599 |
06-05-2013 | #12 |
Look at my note under the "A/C Went Out" thread. My LED was blinking and I never could pull any fault codes out. You may want to carefully remove and disassemble the EEC and replace the large capacitor at the rear of the board where the wiring harness connects - same great quality as those in the Bose amps. Also look for cold solder joints on the PCB and re-solder as indicated.
06-05-2013 | #13 | |
