Old 06-02-2013   #11
Default Re: Starting issue
Connected the clutch wires......replaced what I think was the starter relay....did not seem to jive with the diagram, but the wires were yellow/blck and connected to thec clutch switch....so I think I have it right
Old 06-02-2013   #12
Connmected the clutch wires......replaced what I think was the starter relay....did not seem to jive with the diagram, but the wires were yellow/blck and connected to thec clutch switch....so I think I have it right
The yellow stripped black wire is for the starter relay,thats the ground I believe.
Old 06-02-2013   #13
Old 06-02-2013   #14
Is this the backside of the Starter relay? one with yellow wires?
Old 06-02-2013   #15
The starter relay is the one closest to the column,I think.I pulled the relay and tried to start the car just to make sure.The yellow stripped black wire should be the relay ground,the 14-16 gage wire with the non factory blue splice connector on it.
Old 06-02-2013   #16
Its hard to make out anything in these pictures but this is the splice I made for the new ground,I ran a 10 gage ground wire from the splice to a stud coming off of the dash support.[IMG][/IMG][IMG][/IMG][IMG][/IMG]
Old 06-02-2013   #17
scottfab
scottfab's Avatar
...snip...
-There is a voltage drop when I turn the key, but no clicking, nothing happens
Can you explain "voltage drop"? On the battery? or ???
-Had the battery checked: no issues 12.6 volats
-Checked the alt: outputting 13.8-14.1 volts; steady output
The important number is what the battery measures when the key is turned. If 11.5 - 12.6 then fine.
**If you jump start it, bang....starts right up and will run good for days
**Starter is new
Just by this I'd say battery but more info needed.
Thing about the clutch switch on the early cars is you never want to turn the key before fully depressing the clutch peddle. The contacts can handle the current just fine IF the switch is engaged. Problems happens when the key is turned first and the then the peddle pushed (or at the same time). The switch gets arced in this case. Too many times arcing the switch damages them. I had a problem in 97 but none since then.
Scott
Old 06-02-2013   #18
I almost think its the battery also, it was made 6/2012 and installed this year. They did a load test yesterday and its fine.
We will find out
Old 06-02-2013   #19
Scott by volatage drop I am referring to the fact that when you turn the key volts drop on the dash
Old 06-03-2013   #20
Tyler Townsley
90-91s do not have a relay in the ckt which is the problem, usually the clutch switch activates a relay to better handle the current. As I said the clutch switch takes all the current and becomes unstable. If you follow the purple wire you can just jump around the switch where they go down to the switch.
yler
55 Polo White (Project)
61 Jewel Blue (Sold to buy above)
66 Nassau Blue
68 Torch Red
88 ZR1 Blue
90 ZR1 White
