Old 03-27-2014   #11
ZRXMAX
ZRXMAX's Avatar
Default Re: LT5 short block
Bump
91 ZR-1 #661 Watsons, 3" exhaust, Borlas... Hurst, 4.11s, Samco, RD radiator, gel coated motor... turquise / black
ZRXMAX is offline   Reply With Quote
Old 06-08-2014   #12
ZRXMAX
ZRXMAX's Avatar
Bumpty bump...
Old 06-22-2014   #13
SAM/CH ZR-1
Still available?
Sam
SAM/CH ZR-1 is offline   Reply With Quote
Old 06-23-2014   #14
ZRXMAX
ZRXMAX's Avatar
Originally Posted by SAM/CH ZR-1 View Post
Still available?
Sam
Yes... still availible
Old 07-28-2014   #15
ZRXMAX
ZRXMAX's Avatar
Old 08-29-2014   #16
ZRXMAX
ZRXMAX's Avatar
Old 08-29-2014   #17
How do the Cylinder walls look?
I got everything else on this engine from you
Guess I should just come on down and pick it up
How does the other end look (the flywheel end)?
I am trying to figure out exactly what would make a complete engine and I think I have everything required
Old 08-30-2014   #18
ZRXMAX
ZRXMAX's Avatar
PM sent
Old 08-30-2014   #19
I am assuming missing.......and associated bolts for ALL missing parts?
Flywheel
Front Plate and camshaft chains/sprockets
Chain guides and facings
Oil Filter Housing
Bell Housing
Pressure Plate and associated clutch components
Injector housings
Heads
All the secondary components
HVAC and Purge vacuum components
Plenum
Ignition Module
Coils and associated coil platform
Starter
Harmonic Balancer
Tensioners
I have to study the photos some more
Do you have any of the original missing parts listed or associated bolts?
Old 08-30-2014   #20
ZRXMAX
ZRXMAX's Avatar
Some parts were damaged in the fire such as the ignition control module under the plenum.
I still have many of the "good" parts and will re-inventory them for an accurate record.
The heads you bought from me were from this motor and I have the 20 headbolts in proper protective storage.
Off the top of my head... I have the following.
Flywheel
Clutch disk and pressure plate
Bellhousing
Camshaft plates and chains
Chain guides and tensioners
Harmonic balancer
Idler sprocket for cam chains
Primary chain, ie, crankshaft to cam chain idler sprocket.
No coil packs
No coil pack platform
The starter is questionable.
No injector housings or plenum
