![]() Join Date: Jan 2009
You really should rule out a primary fuel pump starting to fail. That is how mine behaved until if finally just quit. No fun getting a flat bed ride home for my baby.
The test is most disruptive but needs to be because the pressure is fine most of the time. You need to get a pressure gauge taped to the windshield mounted on a long extension such that you can see it as you drive. Note what the pressure may be doing on the stumble. Mine would sometimes set a lean code but not always.
#2 | |
I'm in agreement with you. That was my first thought when he said it only happens when car is up to temp. The secondary pump is commanded on full time by the ECM until 176 deg (or 177, I can't remember the exact number). Once that temp is reached, the ECM turns off the secondary pump and only energizes it when secondary port throttles are commanded open. The secondary pump running full time while the car is warming up would mask any primary pump problems below that temp. Jep |
![]() Join Date: May 2010
Good point P mentioning the TPS, I had similar symptoms when my TPS was a no go.
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
Sounds like an 'exacerbation' of the 'hesitation' that I'm trying to resolve.
Backfire? Maybe lean gases lighting up in the out-pipes, when fuel delivery catches up. I think mine would probably do the same, except that everything is burning pretty cleanly, and the hardware is clean. My MILD lope, just above idle, leads me to believe that fuel delivery coming off of idle, isn't in sync with the air increase, again, JUST COMING OFF idle. Idle @ 0% TO is PERFECT rock steady, no codes. Above 2.4% TO is smooth again too. I still have the secondary-blocking TB gasket installed as well, which eliminates secondarys' leaking air for the diags... I found my bolt (screenshot stuck in 'seeing eye' tool's LED - will post tomorrow), and will resume DataMaster with incremental idle increase with modded throttle stop screw tomorrow or Monday. SOMEone will be able to make something of it, I'm sure. I think this is gonna' be real interesting here... |
![]() Join Date: May 2013
If its a 1990 to 92 could be a faulty or intermittent MAP or TPS sensor. The MAP is used as a direct input to the ECM to help control fuel requirements. 1990 to 92 cars didn't use mass air flow sensors. In general TPS sensors are known to go bad and cause off idle hesitation etc. Both of these can be tested easily. Best guess at this point.
![]() Join Date: Nov 2011
Bob, I've got a fuel pressure gauge. I'll bring it Saturday.-Steve
#7 | |
Thanks for the tables and explanations
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-30-2013 at 09:08 AM. |
Cliff,
As an FYI, the values in these tables are not necessarily stock. |
#9 | |
![]() Fuel Trim and Closed/Open Loop Operation
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS |
#10 | |
