Old 05-05-2013   #11
Fully Vetted
Fully Vetted's Avatar
Default Re: Spark Plug Removal Question
Originally Posted by Racinfan83 View Post
...fabbing a radiator debris screen.
I need to do that as well before the trip to BG. What have some of you other guys done for this?
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 05-05-2013   #12
scottfab
scottfab's Avatar
Here is one example of a screen setup. One of the best kludges I've ever done on the car. It saves SOOOOO much time when it comes to cleaning the radiator stack. I just clean the screen twice a year and that's it. I pulled a small bird carcass out of it once. Stuff just wants to get sucked up in there if you run over it.
http://www.zr1netregistry.com/Inform...or-Screen.aspx
Scott
Old 05-06-2013   #13
Default Debree Screens and Spark Plug Removal
going to look at cleaning the radiator and fabbing a radiator debris screen. Stuff I can do - a bit at a time...
A 90' ZR1, 91' ZR1, and 90' Corvette (L98) all require a bit different debris screens as shown in this post Radiator Debris Screens
I just did a 90' ZR1 Debree screen yesturday
The slot in the Air Deflector is for my Towing Adapter (see item #2 & #3) Lifting and Towing the ZR-1
I got a Blackhawk swivel spark plug socket for that #8 one - read somewhere that one of those was the trick... I hope so..
Number 8 Spark Plug Removal and Test Drive with Jeff Gordon
Old 05-06-2013   #14
Fully Vetted
Thanks, guys.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
