Old 05-02-2013   #11
tpepmeie
Default Re: Initial thoughts on Pete's Intake/Exhaust cam combo
Would you keep exhaust as is, or go bigger on yours? What overlap are you planning on? Be interesting to get Behan's view
Actually, I think 244 exhaust with good ports is plenty. I will keep that, add lift. And go bigger on the intake to reduce the time-area ratio. My current setup peaked torque about 600 revs higher than I intended. The ratio needs work I think.
Now back to your thread....
Old 05-04-2013   #12
Just wrapped up another datalogging session. Overall, this last bin is very close. The new bin has mainly minor tweaks to the VE tables. Very likely this should be a final VE table calc. The BLMs L/R straddle 128 w L being more consistently leaner than the right side, but the gap between the two can also be a function of variance in the two NBO2 sensors themselves. In any case, its at a point of it being almost a matter of semantics. The idle is not baby butt smooth however its pretty respectable between 875-925.
Startup and warmup are good. Cruise and throttle response are right there. Really nice note to the exhaust. With driveability squared away, next up is WOT tuning in a couple of weeks. Stay tuned.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 05-04-2013   #13
Dom, l'd like to see that session!
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 05-24-2013   #14
Results of dyno session. Baseline v Final Config. This compares final tuned versions of Intake cam v Intake + Exhaust cam.
Old 05-24-2013   #15
efnfast
Dom, what did Pete do? P&P and new cams?
Old 05-24-2013   #16
Steve,
The bottom graph is motor w Top End done by me, ported heads by GVD, exhaust, and Pete's intake cams only. Top graph added exhaust cams. Tune is
mine in both cases. I'll post the baseline graph for this morning which was something like 439/389.
Old 05-24-2013   #17
efnfast
How come the 345 curve dives at 5K?
Old 05-24-2013   #18
Pete
Pete's Avatar
Dom,looks like torque picked up across the board,nice.
Enjoy brotha.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 05-24-2013   #19
Look's great , nice work
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 05-24-2013   #20
That's the torque curve and it peaks at about 5200rpm.
