Old 04-23-2013   #11
Default Re: Safety Tip!
Scott, I like that.. might try making one this evening..
Old 04-23-2013   #12
Schrade
HoLY cOW! YiKEs!
Didn't wreck the fender, did ya'?
Old 04-24-2013   #13
Funracer
HoLY cOW! YiKEs!
Ha No! Almost wrecked my fingers tho!
Funracer is offline   Reply With Quote
Old 04-24-2013   #14
scottfab
scottfab's Avatar
Thanks. It's kind of a kludge but provides a sense of safety.
The key is to get the part to hug the shaft but not too hard
so it's easy to get off.
Scott
Old 04-24-2013   #15
WVZR-1
If you're under there and know you're going to be there for a while there's absolutely no reason NOT to use the trusty old "broom stick". A vise grip attached to the prop-rod also works, but they're most frequently used on the heavy steel or aluminum hoods of the front opening variety. Working outdoors under any hood requires something - the small vise grip does real well and you likely already own one. You can wait until you wear out the broom to complete the hood prop section of your "specialty tools" collection.
OP - it was good that you mentioned it! Most DIY guys don't often get to see what the "line technician" does when he first sticks his head under the hood.
Old 04-24-2013   #16
Fully Vetted
Fully Vetted's Avatar
While that's an effective fix at home in your driveway I wouldn't want that or a broom stick holding open my hood at a car show where style points count. And that is definitely one place you would need something to insure your hood doesn't slam down on some unsuspecting oogler who's admiring your nicely PC'ed plenum.
I've "commissioned" a more permanent fix from Carter that'll be a little easier on the eyes for car shows and such that I should have with me at BG.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 04-24-2013   #17
WVZR-1
You've "commissioned" - Interesting! I can't say that "easier on the eye" & Carter are synonymous.
Old 04-24-2013   #18
Bob Eyres
Thanks for the tip. I've never had the problem, but that first shot of that screwdriver looks like an easy solution for the lazy, (me).
O.K. who's going to be the first to make one out of billet aluminum, (of course lined with soft rubber, "no scratches"), for just the right grip.
There will be an extra charge for the engraved ZR-1 logo of course.
Old 04-24-2013   #19
WVZR-1
A correct diameter "ferrite cylinder clamp" with a rubber insert will accomplish the task. Inexpensive and "BLING free" -
Here's one that surfaced quikley at 6.6mm diameter. Might be close.
Old 04-24-2013   #20
scottfab
scottfab's Avatar
Im not at all sure that would work. I don't believe there is that much room "length wise) to put that on the polished surface and I know putting anything on it even if it did fit could adversely effect the seal that must slide over the marred and/or contaminated area.
The other alternative is to just rip out the shock/strut and use a branch from a nearby tree each time. It could be a "Green" solution.
Scott
