04-25-2013 | #11 | |
Re: What now?
If there's an engine rebuilding service in town then that's also a more likely place to check. Last edited by WVZR-1; 04-25-2013 at 09:32 AM. |
04-25-2013 | #12 |
Re: What now?
Rockauto has them for $0.25 ea
04-25-2013 | #13 |
Re: What now?
I don't understand the "fascination" of the Internet parts sourcing. Aside from taking the revenue from your local community that could include "friends, neighbors, your kids activities families and whatever" there's the what will I receive thought. There's a post presently on the CF where the OP is whining about his time spent regarding the receipt of a incorrect part and his taking the time to actually do the install before noticing the difference.
Regarding the plugs and this comment from Pete: The part numbered plug is 5/8 and he mentions using RTV. I don't doubt any of that but what's the reason for the RTV? The fact that the 5/8 plug is 15.875mm would maybe a 16mm plug be a better fit? Don't know, never been there but might one day be there. Thought I'd ask. |
04-25-2013 | #14 |
Re: What now?
no fascination for internet parts sourcing here, but if you come up out of luck locally that is your next option.
What happened to walking into a parts store and asking for a specific part? I went into a local Napa, looking for a longer wheel stud, told them Knurl and length and threading, They Said: What year/model? I said, I don't know, I have the specs They said, you have a part number? I said, I don't have a part # They said, no part number or make/model, we can't help you
04-25-2013 | #15 | |
Re: What now?
The use of RTV hate for someone do all that work to have a vacuum leak and then try to figure out which plug is leaking. Pete
'91 #1635 PoloGreen 350 LT5 11.09 @ 129.27 11.04 @ 128.86 474RWHP 400RWTQ http://www.youtube.com/watch?v=SFNFOhGGlR4 http://www.youtube.com/watch?v=ZlRIOMwaDYY https://sites.google.com/site/peteszr1garage Last edited by Pete; 04-25-2013 at 12:43 PM. |
04-25-2013 | #16 |
Re: What now?
O'Reillys yesterday:
Whats your model year and car? That won't help. I am looking for a non-stock part. Dorman plug 555-108. He looks it up. Nuthin'. They look like a small freeze plug. Do you know what a freeze plug is? Honestly, no. Sigh. At least he was honest. |
04-25-2013 | #17 | |
Re: What now?
each way. If I do not get these locally today I will probably order them and do everything when I get back first week of May. Autozone, et. al. list this item in there national inventory but I was hoping to walk in and grab and go. In retrospect I should have begun my search earlier. Later |
04-25-2013 | #18 | |
Re: What now?
04-25-2013 | #19 | |
Re: What now?
I was always told cup expansion plugs were installed "dry" and not installed using anything other than an installation tool or a socket that is a good fit to the inner diameter of the cup. Never the edges! You of course aren't doing oil or coolant!! Last edited by WVZR-1; 04-25-2013 at 08:51 PM. |
04-26-2013 | #20 |
Re: What now?
Found the plugs at Carquest for $1 each. That is the good news.
The bad news is they were a bi-atch to put in. The problem is the lack of access because the heads are still attached to the block. If heads are pulled banging these in with a hammer and drift would be a snap. The butterfly rod cavities are angled slightly downward when the heads in place. There is no way to get a square hit on the plug. Pulling the heads is a no go for me, so had to go to plan "B". Be forewarned, the following picture may give the Z purist heartburn: I bought a 1 inch C clamp at Ace Hardware for $2and wrapped the end in electric tape. It fit perfectly over the intake wall and into the Dorman expansion plug. I thought I was home free. I screwed that thing as tight as I dared and it would NOT push that plug into the cavity. Then, forgive me, I resorted to the mechanics last resort-vise grips. Again no luck. After several hours of messing with this (yes I tried hammer and wood block, drift, screw driver and socket head) I began to contemplate another option, like filling the hole with RTV or JB weld or plastic bolt and nut, etc. Then, since I could not get them in anyway, went to plan "C": I re-beveled the rounded edge of the expansion plugs and made them just a bit smaller and took just a bit off the skirt as well: Voila! Pushed that thing in finally! Here are 3 of the 4 PS done. I gave up at 8 PM tonight and the other side will have to wait: This was really an unexpected PITA. If you want to pull secondaries with the heads in place I would give serious consideration to stopping at this point: Other obligations backing up so it will be a few days before I get back to it. Later |
