04-09-2013 | #11 |
Re: Group Buy Stainless Works.
Well, now that you mention it, I can supply some of those dipstick brackets you'll need when you install the headers...
PM me if you need me to make one (some) up. P.
04-09-2013 | #12 |
Paul, my header install guy was happy I provided him with your bracket. Anybody doing headers, I would suggest buying Paul bracket. -Steve
04-09-2013 | #13 |
Where does that bracket go? I need to see if the PO already put one on. And is it a replacement for a bad bracket or an additional bracket?
04-09-2013 | #14 |
I didn't do the headers, but I beleive the dipstick needs to be relocated because of the headers, this bracket just shifts it over a bit.
04-09-2013 | #15 |
Must've been done then. PO put on SW headers. I'll look, tho. Thanks.
04-09-2013 | #16 |
Well, if I am ever going to do it, this is probably the best price I will ever see, so put me in for headers & hi flow cats (with thermal coating) sku: ZR1FACTCAT.
I plan on hooking up the air tubes...Can SW include the tubes, or is that something that is done later...such as Marc does??? |
04-10-2013 | #17 |
Meanmyz - good qn.... Anyone know?
My understanding is that the air injection only plays a role in reducing emmissions before the engine is warmed up? I am assuming I could still pass emmissions without air injection (with CATs). They don't do visual inspection here. A question on Thermal Coating.... from what I have been reading on the web there seems to be mixed opinions as to whether it is much benefit when used on SS headers. Is it worth it/necessary? Is there a cheaper alternative anyone would recommend? Lastly... Whats the process to participate in this deal - call up SW directly and mention the forum? Thanks
[SIGPIC][/SIGPIC] __________________ 1990 Corvette ZR-1 #2824 4.10's, Custom PROM, Flowmaster, Top End Port NCRS BC Chapter |
04-10-2013 | #18 |
If you get the headers and cats with the factory connection, where does it bolt to?
90 ZR1 Dark Red/Black, Borla, 4:10, Chip 01 Z06 01 Z06 Lingenfelter 427 Twin Turbo |
04-10-2013 | #19 |
It should bolt up directly to your factory exhaust (or an exhaust with equivalent connections to factory). In my case I have a flowmaster system. Since it bolts up directly to the factory manifolds/cats - I assume it will also bolt up directly to headers with a factory connection
04-10-2013 | #20 |
Does it replace the factory resonator?
