#11 |
![]() Join Date: Jan 2007
Front Tow hook:
One thing to mention the front bracing on this Z is all welded not bolted like a stock car FWIW. ![]() ![]() ![]() ![]() -Daniel |
#12 |
Rear:
![]() ![]() ![]() ![]() ![]() ![]() -Daniel |
#13 | |
No this was someone that I was racing with at the time. He made this for his car and I have just saved the pictures. I'm sure I could mock something up for the dimensions. Daniel |
#14 |
Cliff,
Thanks but I cannot take any credit on the tow hook. The hooks are original equipment on this ZR-1. The rear tow had been removed at some point in the cars life. However the mounting hardware was still attached. I used a leaf spring U to make the new one and it worked like a champ. The original builder of the Z trucked it around on a semi with the race cars and pulled it in and out of the trailer with the hooks. At one point one of the cars failed and they were using the Z to tow it off the track and back to the pits. The hooks seem to have held up good over the years I see no fatigue or distortions to any part of the hook/frame/or body. The rear you could make for less than 10 and the front probably the same if you have the tools to weld it yourself. The front just need to be placed in a break to get the angle. I have been meaning to make a few sets but work and life have me slammed at the moment. Daniel |
#15 | |
![]() Join Date: May 2010
Great stuff and I don't mind being on your waiting list when you have time to make a few sets. Thanks for sharing!!! ![]() Craig
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
#16 |
Absolutely love the tow adapter
Makes loading the car in the trailer soooo easy!!!! Thanks cliff!!!! ![]() David |
#17 |
![]() Join Date: Jan 2009
Here ya go
#18 | |
If these are available, please let me know. If somebody has other suggestions, please share. Thanks |
#19 |
![]() Join Date: Nov 2013
I like the look of this and it is a good idea. How long does it stick out?? I have seen many c5 corvette with tow hooks installed running around all the time. Is this installed with bolts or just to place on metal bar and pull? I am interested in one of these. You never know..... Do you make them?? Price?
ed ramos #3028 |
#20 | |
http://www.zr1.net/forum/showthread....ghlight=towing
