Old 03-31-2013   #11
Default Re: Accessory Console Wiring
AccPlug fuse is good. Cigar lighter has power. Looks like WB interface blown. Oh well.
Well crap!!!!! You sure the unit is not internally fused. Also try this dom un plug it and plug it back in. It may reset. I know longshot but to test cost nothing
Old 03-31-2013   #12
Assume you checked the power by using ground associated with cigar lighter and accessory plug. In other words you did not use a different ground?
Just making sure the grounds are complete with each of those circuits (cigar lighter and accessory plug).
Ohm any and all grounds back to negative terminal of battery.
Old 03-31-2013   #13
Actually I did try that yesterday. WB display went dark and then motor would start and die. I have my MAP sensor connected to WB display. When I disconnected WB interface, motor ran. Reconnected, it died. This happened once before. Replaced module and voila. I'll check to see if it has an internal fuse but I doubt it.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 03-31-2013   #14
Must have over worked the WB. I have a new LC1 I should probably sell
Old 03-31-2013   #15
WB Controller not internally fused.
