Old 03-04-2013   #11
VetteVet
VetteVet's Avatar
Default Re: Who sells a quality door strip belt molding strip? (upper door by window ) ---
Originally Posted by Fully Vetted View Post
Good luck. I couldn't find it here.
This link is a little more specific. $38.00 for outer and $30.00 for inner.
http://keenparts.com/pages/Catalog3....3035&year=1991
I've had nothing but good experiences with Keen.
Jep
Old 03-05-2013   #12
Fully Vetted
Fully Vetted's Avatar
Aah...listed as a door seal and not weatherstrip.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 03-09-2013   #13
Cal55
How difficult are the outer ones to change? I assume you have to remove the door panel.
Thanks,
Joe
Cal55 is offline   Reply With Quote
Old 03-09-2013   #14
Fully Vetted
You'll need a rivet gun. Take off the door panel, drill out the rivets and then reverse the process.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 03-09-2013   #15
Cal55
Thanks for the information, that doesn't sound like it's too bad of a job. My passenger side has a crack in it, but it's not very noticeable so I may leave it for now.
Joe
Old 03-10-2013   #16
Fully Vetted
If I was going to do one I would go ahead and do both. May save some time refamiliarizing yourself with the process. And you already have your needed tools out. Most likely you'll be buying a pair anyway since I think that's the only way you can buy them.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 03-10-2013   #17
Cal55
Good point, usually the second time goes much smoother. I'll take a closer look at it when the weather breaks, which should be soon hopefully!
Thanks,
Joe
