Old 02-27-2013   #11
LancePearson
LancePearson's Avatar
Default Re: LT5 Engine Paint and Vette tools for painting, etc.
you need some tools to paint and since I mentioned the tools I just got to help where my hands are too big I'll show them. The pen is normal pen size and the forceps from Amazon were $12, the set of four 16" long needle nose pliers was more, zero, 30 degree bend, 45 degree and these, 90 degree so with the magnetic probe, the wire flex probe and these things I can pretty much get most things now, big hands and all. Thanks for the painting methods...will try when it comes up on the list.
Lance Pearson
Chester, Virginia
[COLOR=red][I]'76 L48 four speed[/I][/COLOR]
[COLOR=red][I]'91 ZR-1 #00682[/I][/COLOR]
Net Registry #1461
LancePearson is offline   Reply With Quote
Old 02-27-2013   #12
Originally Posted by Scrrem View Post
I'm right there with you Lance, I can't do the small detailed work like that. My guess would be a fine brush and just wipe any overlap paint quickly before it sets.
I removed my parts and sent them to the pro (Mark H.) and they came back looking awesome.
Rich
Rich....
That engine looks awesome!!!!!!!!!!
Old 02-27-2013   #13
vilant
Originally Posted by ZZZZZR1 View Post
Rich....
I agree. I thought our plenums were powder-coated...no? Is that something that is done aftermarket?
Joe
1990 Bright Red ZR-1 #2599
Old 02-27-2013   #14
Kevin
Kevin's Avatar
paint from the factory, pc/clear, paint/clear is aftermarket
Old 02-27-2013   #15
vilant
Gotcha, thanks. Wonder how well the spray can paint blends, and if the heat will effect it?
Joe
Old 02-27-2013   #16
Daniel_Mc
Daniel_Mc's Avatar
Paint the letters first then (after they dry) fill with wax or wax type epoxy. Clean the plenum or cam cover and paint. After that remove the filling. That is how we PC'd the plenum on the Z. Did the white first then did the black.
Daniel
Daniel_Mc is offline   Reply With Quote
Old 02-28-2013   #17
Starman
Starman's Avatar
To paint the lettering, I use a Uni brand (oil based) paint marker available from most major office supply stores. They come in wide and narrow tip. We used these in the automotive industry to signify certain quality checks had been performed on parts. If you goof, a quick clean up with mineral spirits can save you.
As far as the Duplicolor yellowing, have not noticed it with the Cast Aluminum color, but the clear definitely yellows.
Starman is offline   Reply With Quote
Old 02-28-2013   #18
RHanselman
RHanselman's Avatar
Originally Posted by Z51JEFF View Post
Lingenfelter also sells the same shade of silver.Cant remember what I paid for a can but I do know it was alot more than $6.00.
I know Jerry has it...
Cheers,
RH
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
RHanselman is offline   Reply With Quote
Old 02-28-2013   #19
That may be the problem then...The clear coat.
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 02-28-2013   #20
2ZR1S
2ZR1S's Avatar
Originally Posted by LancePearson View Post
I've seen the letters looking really good but I've been hesitant to paint them. How does everyone do it, with a fine artists small brush dipped carefully? I'm not a very good "finish" person so it's been left alone so far.
Buy the automotive touch up paint with a ball marker on one end of the cap. I did this and it turned out great and was easy. Just "dab" until you get it filled.
Jon R. Member #490
1992 ZR-1 Arctic White/Red
2008 Z51 Silver 6 spd (Daily driver)
2ZR1S is offline   Reply With Quote
