Old 03-01-2013   #11
Default Re: Rear wheel HP estimate
420 at the wheels..SAE-corrected or standard-corrected?
Wel now... that IS the question.
It seems SAE standards evolved over time, introducing the oppotunity for different results for the same run, depending on which "standard" was applied. Add to that some calibration issues, and operator's attention to detail.... Makes for ambigeous results at best.
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 03-01-2013   #12
Fully Vetted
Fully Vetted's Avatar
Originally Posted by Pete View Post
When i dyno'd that Z it made 425 SAE Corrected
I heard Corey got 428 out of it.
I think 430+ should be possible from that Z but then again every Dyno is different 420-430 is withen tolerance...
Yeah, you've talked to him since I have. I'll have to update my sig!
I'm still chasing Paul for power on stock cams, though.
Since then i re-ported my plenum/IH's a bit bigger i also mention i reduced rotational weight between pullies,ATI balancer,clutch/flywheel i'd say 25lbs maybe more and about 200lbs dead weight.
Pete, did you do the lightweight pullies on my car or is that something Michael did after you worked on it? I'm trying to determine if your 425 number was done before or after those were installed.
Originally Posted by Nacho_ZR1 View Post
Wow how'd you reduce 200lbs? Inquiring minds wanna know
Going from a steel flywheel to an aluminum one is most of it.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 03-01-2013   #13
Fully Vetted
P.
Paul, please explain the whole "SAE corrected and standard corrected" situation. I know corrections are made so that different pulls at different altitudes can be compared but that's about the extent of my knowledge on this. And I'm not even 100% confident I'm correct on that!
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 03-01-2013   #14
Nacho_ZR1
The steel flywheel weighs that much??????
[B][U]---SOLD BUT NOT FORGOTTEN---[/U][/B]
[SIZE="1"][SIZE="2"]1992 ZR-1 #483
[COLOR="DarkRed"]Dark Red Metallic[/COLOR]
[U][B]Mods[/B][/U]
-Jeal headers
-Stock exhaust with X-pipe
-4.30 Gears
-Corey Henderson tune
-375 RWHP[/SIZE][/SIZE]
Nacho_ZR1 is offline   Reply With Quote
Old 03-01-2013   #15
Fully Vetted
Actually, I'm sure several can explain this. The floor is open...
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 03-01-2013   #16
Pete
Pete's Avatar
Stock flywheel is 36 lbs, aluminum is 13.5lbs almost 23 right there.
Spare tire and tools 50lbs.
http://zr1specialist.com/HAT%20Web/T...0Reduction.htm
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 03-01-2013   #17
Pete
Pete's Avatar
I think he did the pullies afterwards they are not my pulley design,the older pullies were a bit too heavy for my taste LOL
Don't chase dyno sheet #'s if that's all you want i can give one just tell me what #'s you want.LOL
Like i mentioned before all dyno's are different i used to go 3 different dyno's and all were different but withen 10rwhp one was way out there low about 30,i'm sure if i droped off a few stacks of cash they would get me 30 lol
This why i say 420-430 is withen tolerance.
My Z did 466 on one dyno and 474 on another which do i believe,of course i will post the higher # :-)
Dyno's are tuning device/tool.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 03-01-2013   #18
Pete
Yep. The rotational mass difference has been demonstrated to be the equivelant of ~ 15 rwhp on an inertia dyno comparisons. Might be worth an tenth or so off the 60 foot times, ya think?
90 #1202
Sans secondaries
Old 03-01-2013   #19
Nacho_ZR1
I think he did the pullies afterwards they are not my pulley design.Pete
So do you sell lightweight pulleys or have a source that does? I'd like a set
[U][B]Mods[/B][/U]
-Jeal headers
-4.30 Gears
Old 03-06-2013   #20
Hib Halverson
P.
That is not correct.
SAE Standard J1349 has existed for decades and is still used today. Virtually all chassis and engine dyno operating software corrects to both "standard" and SAE. Some also correct to various DIN standards, as well as the JIS standard.
The difference between "standard" and "SAE" is the atmospheric conditions to which the dyno data is corrected. The makers of aftermarket performance enhancments like "standard" corrected because it typically makes for "bigger" number. Engineers always use "SAE" corrected because the SAE J1349 standard specifies an atmospheric correction factor that is more "real world".
The executive summary of the two atmospheric corrections is: "standard" considers that the engine was run on a 60°F day with 0% humidity and a barometric pressure of 29.92 in-Hg. SAE J1349 considers the engine run on a 77°F (25°C) day with 0% humidity and a barometric pressure of 29.234 in-Hg (99 KPa).
How can these two standards affect dyno results., during a recent chassis dyno test I did with a 2012 Z06, if I correct the data to standard, the best of four passes was 473 at the wheels. If I correct the data to SAE J1349, it was 454.5 at the wheels.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
