02-22-2013 | #11 |
Re: Repair Shop?
this is exactly what i was going to suggest. is the key making proper contact?
02-22-2013 | #12 |
Re: Repair Shop?
02-22-2013 | #13 |
Re: Repair Shop?
Going back to my original question. Any one know of a good ZR1 repair center in Texas? Around Dallas or Fort Worth would be good....Thanks route 66
02-22-2013 | #14 |
Re: Repair Shop?
the closest you're going to find is New Braunfels. Corey Hendersons shop. http://www.hendersonperformance.com/
02-22-2013 | #15 |
Re: Repair Shop?
there is another map sensor under the computer ck to see if its connected . if you have a 90 .you could have the problem i had turned the key top on light lit but no secondaries .so i tried turning the key back a little and poof they worked . i just replaced the key switch with a toggle switch .
02-22-2013 | #16 | |
Re: Repair Shop?
02-22-2013 | #17 | |
Re: Repair Shop?
Some time back I read about there being 2 shops in Dallas or Fort Worth I thought they might still be around....Anyway thanks again...route 66 |
02-23-2013 | #18 |
Re: Repair Shop?
See my post in another section.
He is one of the best. And well worth the ride. Henderson Performance Technologies , Corey Henderson Address: 1660 Texas 337 Loop, New Braunfels, TX 78130 Phone: (830) 620-1117 http://www.hendersonperformance.com/
02-23-2013 | #19 | |
Re: Repair Shop?
Cheers, Ron
Ron Hanselman Founding Member #80 CM Lifetime Member #1093 1991 #383 Twin Turbo 1993 #099 Ruby, Jeal 368 w/Snake Skinner body 1961 White with Red Int |
02-23-2013 | #20 |
Re: Repair Shop?
i drive 1600 miles one way to have him tune my 2 zr1s
