#11 |
![]() Join Date: Mar 2007
Let me correct that 702 had a shim, that went into 966...I will check the 966 motor tomorrow
#12 |
![]() Join Date: Feb 2009
The engine I purchased and am building not did not have the sensor or shim present. I guess the only way I will know if I need a shim or not is to install the sensor and measure the clearance.
#13 | |
![]() Join Date: Oct 2004
I just looked and there is 3.0mm, 3.25mm and 3.65mm applications and it does say '90 - '95! Last edited by WVZR-1; 03-11-2014 at 09:05 PM. |
