#11 |
Lambda is lambda regardless of the stoich which is why tuning for E85 can be simpler than it looks. Lambda is the measure of O2, not AFR. We have 10% ethanol here in the Midwest and I reset my calibration to use 14.3 as stoich.
#12 | |
Injector opening time will vary based on pulse width and voltage. The calibration has modifier tables for both. Different injectors will have differing characteristics for both.
#13 | |
![]() Join Date: Jun 2005
What I was asking is how many here on the net who are doing their own cals are bothering with figuring what's stoich, or are tuning for lambda regardless of the fuel. Also, my understanding is E10 is seldom actually 10% ethanol and that E10 out of pumps varies widely in how much ethanol is actually in the gas. I'm looking for any evidence of that. Do you test your blended gasoline or have you just assumed it's 10%?
#14 | |
![]() Join Date: Apr 2007
#15 |
I had a Corvette tech at a Chevrolet dealer who has Kent-Moore's gasoline tester that he's tested pump gasolines said to be E10 at anywhere from 5% to 32% ethanol.
I got to thinking. If you calibrated for E10 and got stuck with some 5%, no big deal, but if you calibrated for E10 and unbeknownst to you, got a tank of "E32" then ran the car hard? You'd be getting poop-loads of KR and probably burning pistons. That piqued my curiosity enough that I wanted to get the Kent-Moore tool. I found it's just been discontinued, however, I've found some other "ethanol test kits" on the market that might work well. Still researching.
Hib Halverson Technical Writer former owner 95 VIN 0140 current owner 19 VIN 1878 Last edited by Hib Halverson; 02-28-2013 at 07:55 PM. Reason: added content. |
#16 | |
![]() Join Date: Jan 2009
Jep |
#17 |
#18 |
![]() Join Date: Jul 2010
Even if you figured out the E% of the fuel your putting in the tank, that will change a bit depending on whats already in your tank before filling. The emptier the tank before filling the better.
12570260 Lists at $639 and can be had for $378. The more modern ECM's run a virtual ethanol meter, using inputs from the O2 sensors to tell the ECM what E% is being fed to the engine. This is the "Stoich. AFR vs. %Alcohol in Fuel" Table from a 2011 GM truck Stoich Ethanol Ratio Percentage 14.670 0% 14.314 6.25% 13.958 12.5% 13.602 18.75% 13.245 25% 12.890 31.25" 12.534 37% 12.177 43.75% 11.821 50% 11.466 56.25% 11.109 62.5% 10.753 68.75% 10.397 75% 10.041 81.25% 9.684 87.5% 9.329 93.75% 8.973 100% ethanol There is even a table that compensates for the way different alcohol percentages effects the speed at which the fuel evaporates off the cylinder wall. Can you just keep adjusting the stoich point until O2 trims fall into line? Obviously a pain if burning chips, more for a tuner running an emulator. peace Hog |
#19 |
Hog,
You'd want to set the Stoich for the known fuel then tune. That's what I have done. It'd be nice to have a sensor for real time fuel analysis then dynamically adjusting Stoich. Has anyone ever done a FlexFuel using Speed Density rather than MAF?
#20 | |
peace Hog |
