![]() Join Date: Jun 2005
My '95 has the U1F/UXO "Delco-Bose Gold" sound system. It's true that the Amplifier/Speaker assemblies have problems, mostly with capacitors on the amp PC boards going out, but sound wise, it's hard to beat them considering their 25-year old technology still makes pretty good sound and installing an aftermarket speaker arrangement that is as good or better is a lot of work.
What I've always disliked about the Bose, is the radio control head, mainly because it lacked a balance control. After nearly 20 years, the unit in my 95 had a crackling volume control and a CD player that was often displaying "err". Plus, it had no way to directly connect my iPod. To listen to stuff on it, I had to use an FM adapter which was a pain in the butt. To address all these issues, installed a Zip Products "Pioneer Conversion Kit" (PN XR183). The Pioneer is made with 25-year newer technology, supports direct connection of an iPod or other USB device and allows adjustment of the speaker balance. In addition it supports the adding a subwoofer, if you want it, along with an external power amp, if you're inclined to go to an aftermarket amp and speakers. As I was sticking with stock speakers, I replaced all four Bose amplifier Speaker assemblies because I had one with a bad speaker and another with an amplifier problem. I decided to swap the other two on GP. Now, there are no replacements for the left front speaker assembly so I had to "rebuild" one by using my existing speaker enclosure and new Zip speakers. The result was a significant improvement in the sound quality along with no more crackling volume control, a CD play which worked right and simple connection of an iPod. In fact, I am so happy with the results I posted a couple of articles at Corvette Magazine.com covering what I did. Check it out!
