Old 01-30-2013   #11
Schrade
Default Re: The Rest of the story!
Originally Posted by ghlkal View Post
I'm glad this worked out!
Any idea what fixed your dim dash lights?
I have the same issue. I've had the dash out to make sure all the lights work, and I've cleaned the two main grounds on the bellhousing, but the dash lights remain dim.
Dim? Or flicker? Do you have DTC 41 [?] for CCM --- LCD Voltage Hi / Low spec???
Old 01-30-2013   #12
ghlkal
ghlkal's Avatar
No flickering and no codes. Just dim. Dash will brighten with lights on and photocell seems to work, although I've wondered if the photocell is an issue.
