Old 01-20-2013   #11
WVZR-1
Default Re: What shift light are you guys using? ---
That actually looks pretty good. The horizontal deflector seems to detract from it's appearance somewhat. After seeing the snapshots I might consider a bit of modification to what I had imagined the vent would require that I had already posted. Requires maybe more thought, the deflector though does seem like an "obstuction".
If you used the 3/4" mini I would think you could "counter-bore" the A/C vent from the back-side and bring the Raptor to within maybe 1/8" - 3/16" of the face of the vent and secure it with an epoxy. I would think it would go undetected to anyone other than those who knew it were there. A second center outlet could be used so you could always revert back to the stock form.
A 3/4 Vitrified grinding stone ($3) from a hobby shop in a drill press could accomplish the "counter-bore" or if you were really steady I guess you could use it in a Dremel.
Old 01-21-2013   #12
cvette98pacecar
You could bring it all the way forward with the way it is mounted. I choose this way to keep a stock dash appearance. I would also suggest against epoxy as you wont be able to remove the vent without damaging the shift light or vent piece.
A step drill bit works perfect as it leaves the ridge which acts as a seal, once you push the shift light and vent into place the fitting is tight enough to hold the vent in place without the screws.
Old 01-21-2013   #13
Here it is installed behind the AC grille. It is out of sight, until the light comes on!
In the pic, not all the LEDs are lit. That is because on startup the lights are sequenced on and off in a pattern for a couple seconds as if to say, "Hello! I'm awake!" Trust me, when all 7 LEDs come on, there's no missing it!
As for mounting it, I used a drill bit and carefully opened the hole up with a Dremel grinder so the Raptor would just fit with a single wrap of electrical tape around the barrel of the light at the point of contact. Then a couple wraps of tapein front of the contact point so the Raptor would not slide back through the hole to fall behind the dash.
It fits snuggly, and to adjust the shift light rpm, I simply pull the light out to change the setting, and push it back into the hole for a nice friction fit.
To run the wires, I removed the carpeted hush panel screws and used wire from a wire coat hanger to fische the Raptor wiring from the dash where I could grab them and route them over to the big C-100 connector.
I connected the Raptor tach wire to the white tach wire at the big C-100 bulkhead connector, just up and slightly left of the toes of your left foot. there too is access to 12 volts when the ignition is ON. (See the FSM for details).
P.
Old 01-21-2013   #14
I like it on the A pillar for 2 reasons:
1. Can put it at eye level
2. Easy access to change shift points.
The Raptor light is small enough that it hides behind A pillar pretty easily.
Old 01-21-2013   #15
alwayscode390
WOW, that is pretty slick guys ... thanks for the pics and for educating me on the a/c vent ---
alwayscode390 is offline   Reply With Quote
Old 01-21-2013   #16
mgg
When mounting the 'raptor" shift light behind the vent, I would suggest using a "forstner' bit I believe its called. I used it on mine as as the post said it makes for a perfect friction fit. You only see it when you need to. I absolutely love mine and would suggest it as agreat way to have a stealthy shift like that is protected and works well. Nice pics by the way. The shift light is right in front of your face so you never have to take your eyes off of whats important. Not to mention not having to worry about watching the tach. It is a sweet upgrade.
mgg is offline   Reply With Quote
Old 01-22-2013   #17
Originally Posted by alwayscode390 View Post
I have a dash mat too , and would rather not screw into anything. That looks like it will work perfectly ... whats the dimensions on that light? ---
About the size of a roll of nickels
Old 01-22-2013   #18
alwayscode390
OK, thanks ---
Old 01-22-2013   #19
2ZR1S
2ZR1S's Avatar
Mini auto meter. This is CJ's car now. I had in several cars and they work well. It is the best picture I could find.
Jon R. Member #490
1992 ZR-1 Arctic White/Red
2008 Z51 Silver 6 spd (Daily driver)
2ZR1S is offline   Reply With Quote
