#11 |
![]() Join Date: Oct 2004
If you really want to use a full-size bolt this is the spacer, ideally you would use those bolts Dynomite posted or the one I suggested that you can use for "test-leads" BatteryTender or whatever. Of course I like my choice "best"!
The spacer (GM# 12354951): ![]() |
#12 |
![]() Join Date: Jun 2012
Thanks guys. I paid 12.99 for each replacement cable and only used the bolt
#13 | |
The thread length on a battery bolt is an engineered spec that is meant to generally keep one from "bottoming" and fracturing the battery case or breaking the terminal from the battery internal structure. Doesn't always work, some still find a way to ruin a battery!. |
#14 | |
#15 |
![]() Join Date: Jun 2005
I had exactly the same problem about three weeks ago on my 95. Two new side terminal bolts fixed the problem.
I have a number of vehicles with side terminal batteries but my ZR-1 is the only car that's ever had a battery cable bolt wear out and I've changed the battery may half a dozen times in 20 years. Go figure.
#16 | |
![]() Join Date: Nov 2007
U? P. |
#17 |
#18 | |
***8mm 6-point I must admit I grab occasionally You need I believe just the 5/16 for battery bolt and the 9/16 oil drain plug the rest metric! Last edited by WVZR-1; 01-26-2013 at 02:44 AM. |
#19 | |
The OE/GM drain plug is a "no go" with a quality 14mm end-wrench, it's an SAE threaded part why would it have a metric head. ![]() |
