#11 | |
![]() Join Date: Jun 2012
http://www.totalcardiagnostics.com/toad/ and yes the older model Z's will have 12pin, the later model Z's could have 12 or 16 pin. You have to look at the connector to be sure on the later model ones. |
#12 | |
#13 | |
#14 |
I use "Datamaster" for my 1991 Syclone and LOVE it ... real time data for every parameter of the engine you could think of.
Looks like I may pick this up now too if this is the only option we have for the ZR-1 ![]() |
#15 | |
![]() Join Date: Oct 2004
Datamaster files: http://www.ttspowersystems.com/DataM...ownloads2.html Last edited by WVZR-1; 01-17-2013 at 02:52 AM. |
#16 |
WOW, you just saved me $100 ... thank you very much !!! ---
#17 | |
Should you need an ECM for your Scyclone I believe I have new in box for it Last edited by WVZR-1; 01-17-2013 at 02:59 AM. |
#18 |
![]() Join Date: Sep 2011
I bought the Innova but havent used it yet .. But if there is hardware ( with basic instructions ) out there to use my laptop - keep he headed in the right direction. I need more info.. Thanks
#19 |
I don't know about presently but I'm quite sure Marc H used Diacom because I sent my Diacom program to a fellow so he could send Marc logs that he generated with it to finalize the tune on his 415.
The only fault with the Diacom is that it requires a serial port although I've never tried a USB to serial converter and it is slow. I have an older 600 ThinkPad that it is on and I've not used it in quite some time, a very long time. I need to replace the screen and it's been apart for quite some time. I've a Tech1 also. If you've a very old laptop with serial port you might consider this: http://www.rinda.com/auto/auto.htm |
#20 |
Started digging into the programs, this software is not for the computer illiterate, lol. The dyno and acceleration tests are only for OBD II cars
