Old 01-16-2013   #11
Default Re: Weepy Hose?
Originally Posted by msmoore View Post
I am in the process of changing the oil cooler lines and noticed a small amount of coolant on the cross member near/under the engine coolant hose. I have not noticed any significant loss of coolant. Is it possible for these hoses to "weep" through? These appear to be all original hoses on a '90 with 29K miles. This looks to be a tough job since I cant even see the clamp on the engine side of that hose.
Any updates ?
Old 01-16-2013   #12
msmoore
Any updates ?
Not just yet. I went ahead with the oil cooler line replacement and that went well but need to order a full set of coolant hoses. I figure if I'm going that far, makes sense to replace em' all. I'll probably go with Samco.
I still have a lot of greasy mess to clean up from the oil leakage.
I must admit, it looks like a pretty tough job to get to all of those water pump bolts. I'm somewhat of a novice mechanic but pretty sure I'm up for it. At least I have a nice heated garage.
Thanks for checking in. I'll keep you posted.
msmoore is offline   Reply With Quote
