#11 |
![]() Join Date: Sep 2012
![]() Separated at birth Really it's just the front that is similar. Vette is much more angular. I like both till we get to the backside.
_________________ 1994 AB/Grey #141 430 RWHP/392 RWTQ FBI Lyposuction / Secondaries relieved of duty / SW Long Tube Headers / Corsa Exhaust / FIC SS Injectors / MSD Coils / Lightweight Pulleys / Corey tuned B & M Shifter / Aluminum Flywheel / Samco Hoses / Shelby Series One's / C4 No Flex Frame Stiffener BBC - Bling By Carter: Custom ZR-1 Center Caps / Custom Plenum Plate / Air Box Knobs / TB Cover / Oil Filter Cover Last edited by Fully Vetted; 01-14-2013 at 12:02 AM. |
#12 |
Body Double:
Body double: Just sayin'...
#13 |
I like it...cant wait for higher performance versions to surface. So far the Viper has my attention.
#14 |
Scott,
2000 psi is not all that high. Common rail Diesel engines today run with fuel rail pressures of 25,000 psi.
#15 | |
![]() Join Date: Jan 2009
I don't know of a corvette or other gasoline engine with 2000 psi.
#16 |
Definitely has a few "sharp" angles like the Aztec.
I suppose I'll get use to it like a bad fitting tooth crown.
#17 |
![]() Join Date: Jul 2004
Monstrous carbuncle... I don't have a problem with different, just fugly...
Dave
1991 #1516 Black/Black davidmkelly.com Author of fast-paced, sci-fi thrillers. |
#18 |
I'm with David (fully vetted), I hate the new c7 azz and love the accurate pictures!!!!!
Thanks, you made my morning! ![]() David |
#19 |
![]() Join Date: Mar 2004
#20 | |
![]() Join Date: Feb 2012
Is it not to better vaporize the fuel; like in the Chevrolet Traverse??? ![]() |
