Old 12-27-2012   #11
Default Re: Post pics of wheels with a lip / deep dish ---
I like the Series One w a gray PC center hub. Someone had them done that way on a black ZR. Looked awesome.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 12-27-2012   #12
cvette98pacecar
18X10 front 18x12 rear OZ 91 Aerobody
17X9.5 front 17X11 rear OZ. 93 Ruby
Robert J. DeMarco
[SIGPIC][/SIGPIC]
NCM Lifetime Member #2655
Pacecar Registry Member
1991 Shinoda Aerobody Spyder,
1998 Pace Car
Old 12-27-2012   #13
Scrrem
Scrrem's Avatar
Here are my Fiske's...
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 12-27-2012   #14
Jagdpanzer
Jagdpanzer's Avatar
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 12-28-2012   #15
Fully Vetted
Fully Vetted's Avatar
Originally Posted by Daniel_Mc View Post
You are in the same spot I am in. The Gen I Dymags will not clear those brakes. I have AP Racing Brakes on the Z and Rippie's Wilwood set up on the 89. I don't think the shelby wheels will clear either. You can either refinsh the A Molds go Fikse, CCW, or Gen II Dymag for starters. Just make sure whoever you use that they know that brake set up is on the car. Most use a custom hat on the rotor that will push the wheel out some and this will cause wheels with an offset for a normal C4 (Z or not) to stick out.
Daniel
BTW those look like aftermarket A-Molds if you run OEM you will have just a hair more room.
You can move the center collar out on the Series Ones to clear. I haven't done it but some of the other guys here have done it.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 12-28-2012   #16
Sometimes clearance is an issue regarding the radius of the wheel and not the face of the caliper. =Jeff= has Series ones and the C5 calipers he had were very close to the barrel of he wheel. He also needed to move the hub outward for clearance. His Brembos have better clearance.
Old 12-28-2012   #17
alwayscode390
That seems to be how these calipers are with the current A-Molds... the radius is REALLY tight, I almost think the passenger side has made contact and dragged a little at some point. ---
[SIGPIC][/SIGPIC]
01' Dodge Viper GTS
11' Ford Raptor
90' ZR-1 Corvette LPE #699
alwayscode390 is offline   Reply With Quote
Old 12-28-2012   #18
secondchance
Alwayscode390,
I also run Fikse Profil 10s - 18x9.5 front and 18x11 rear - hand polished by Jagdpanzer.
I suggest that you consider possible conversion to 6 piston (front) and 4 piston (rear) hi-perf calipers while selecting which wheels to go with. Deep dish style wheels exudes "performance" look from the 70s to 90s. But deep dish design don't work well with modern day hi-perf calipers.
Car had just gotten off the floor jacks and the suspension had not fully settled yet.
Old 12-28-2012   #19
efnfast
I have the 1st Gen Z06 wheels. They appear made for the ZR and give it a very Ferrari type of look which I like quite a bit.
Here's a pic with polished Z06 brake caliper:
Side View:
Wheel/Fender fitment:
Wheel well fitment:
Nice Dom, I don't think I ever saw the finished product.=D>
Old 12-28-2012   #20
Here are some dymags!
Fronts with C6 brakes
Rears with deep lip
