Old 12-20-2012   #11
Default Re: Rear Suspension Alignment
After replacing the bearing and if required the rear spindle Id suggest a 4 wheel thrust alignment.
Old 12-20-2012   #12
ZR1North
Good suggestions guys - thanks. Re the camber, here are the before and after alignment readings (for the rear):
Before Alignment
Left Rear Camber: -.5 Right Rear Camber: 2.4 (could see it tilted out at the top)
Left Rear Toe: -.15 Right Rear Toe: -.41
After Alignment
Left Rear Camber: -.1 Right Rear Camber: 0.0
Left Rear Toe: .02 Left Rear Toe: .03
ZR1North is offline   Reply With Quote
Old 12-21-2012   #13
Hib Halverson
If your rear wheels are offset 1/2 inch, that huge.
Two things to check and you may need the uniframe dimensions which are in the factory service manual.
First, you need to see if the rear frame rails are bent in the areas where the rear cross member is attached.
Second, you need to inspect the rear crossmember, which also is the rear diff cover to make sure it's not deformed.
For both wheels to be offset, since the axle shafts and the strut rods locate the wheels and both connect to the rear axle housing, that housing has to have moved sideways. The only way that can happen is if the frame is damaged, the rear cross member is damaged, the rear xmember mountings are damaged or some combination of all that.
Once you determine what parts of the car's rear structure have been damaged and make repairs, then move onto any damaged trailing arms, lateral links, bearings, hubs and etc. Once you have those items addressed, them do you alignment.
You musta whacked that curb a good one, that's for sure.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 12-28-2012   #14
ZR1North
Update: Took the right side upper and lower spindle control rods off and can now see bends that I couldn't see while the components were on the car.
Going to install the new control rods, new bearing assys, and loosen all the bolts where the rear diff mounts to the body - hoping the new parts and slight pull on the rear diff will restore things to normal before heading for another alignment.
Learning about polyurethane vs rubber bushings in the process. Seems like polyurethane has more merits than I thought.
Thanks for the advice!
Old 12-28-2012   #15
batchman
Glad you found your culprit, and that it was something readily serviced.
Poly does have some disadvantages though. It will cold flow so if it's in a stressed location it won't keep a perfect shape, and it gets pretty squeaky if not set up to be lubed and kept after.
Harder rubber is a better choice for the street, of course that's not so easy to do. Delrin is a more durable choice but will be more harsh.
Cheers,
- Jeff
