#11 |
Thanks for verifying what he says is correct. Did lpe used to use borla and now use corsa exhausts? Thanks for the idea of contacting lpe directly. I have the vin ---
#12 |
#13 |
Yeah the 475hp package. Is that the 368? Its a 1990 so I'm sure its the early manifold---
#14 |
![]() Join Date: Sep 2012
At some point you will have to decide whether you want a modded car or an original because you will come across both. The best value comes from buying a car that's already had the injectors done as well as the upper end ported. Do that with some good headers and exhaust and you'll be in the 525 CHP range.
If you're wanting original you're still going to need to do the injectors if they haven't already been done. One thing to check is the tires as these puppies are quite expensive. But, the first thing you need to figure out is what color because some colors are only available is certain years. Once you figure that out just be patient and DO NOT SETTLE. I wanted a '94 Admiral Blue with Grey interior and it took me less than a month and I got the exact car I wanted. Twice I almost bought 2 different Red/black cars. I'm so glad I waited.
#15 |
![]() Join Date: Jan 2009
Careful buying "modded" cars.
Who knows what you'll get and what parts you'll be able to get. If it's too much of a Rube Goldberg you'll be stuck with it when it breaks. Moderate mods that are well documented are best IMHO.
#16 | |
#17 |
![]() Join Date: Mar 2004
Modded..........exceptional grin factor , Worth every penny.
#18 |
![]() ![]() Join Date: Feb 2010
I got lucky when I found my Turq car. Tight, nice in/out and 55k miles. It had a spun bearing and the price was exceptionally right.
HEAVILY modded and done right. After a trip to Pete, it's awesome to drive. Don't be afraid of a modded car. Just make sure whatever you buy, you have someone knowledgeable to help you inspect it.
1988 KOH Prototype EX5023 sold 1990 ZR-1 #444 Convertible 1990 ZR-1 Black #966 1991 ZR-1 Quazar Blue #296 1957 Duntov SS Project Last edited by Blue Flame Restorations; 12-16-2012 at 01:15 PM. |
#19 |
![]() Join Date: Jan 2010
My 1991 White/Red ZR-1 is for sale:
http://www.allvette.net/1991-Chevrol...-19382/4187135 Call me at 215-280-4204 if interested. --Rick Moore |
#20 |
I have gotten the VIN of two 1990 zr1's.
They are both identical in the sequence until the middle/end where one is a "j1l" and the other is a "j3l" ... one is a early number car, one is a late number car. What can you share with me on that? I go tomorrow to look at both of them , thanks ![]() |
