#11 |
![]() Join Date: Aug 2012
Yun,
Good luck with the fix and I know you will enjoy the short shifter.
#12 |
![]() Join Date: Aug 2006
#13 |
Ok, guys;
![]() 8 am this morning WAZOO trailer service shows up and shortly thereafter Jim and Darrin show up to help. We push the car out of the garage and load it up. We head over to Rich's and greeted by Rich and Phil. ![]() Transmission removed - Black and Blue Tag! I wonder if this means this has the original max. torque rating or lower rating of the Blue tag... ![]() Upon disassembly we find a failed clutch fork. It seems about 130,000 miles is what one can expect prior to fatigue failure. ![]() I figured why just repair when you can repair and improve? We pulled the factory shifter and installed a Bill Boudreau short throw shifter. ![]() Also patched a hole in the rubber shift boot with 3M 08609 - recommended by Bill - since I couldn't find a new piece. Bill's shifter made the car feel more "sporting" and contemporary - definately worth the effort. WAZOO struck again and exhibited an incredible spirit of brotherhood. A great big thanks to Jeff, Rich, Phil, Jim, Darrin and David! Last edited by secondchance; 12-16-2012 at 05:29 PM. |
#14 |
![]() Join Date: Dec 2005
So did you drive her home or just a short test drive?
#15 |
#16 |
I would suspect throw out bearing first. Clutch fork bend would present over a period of time as opposed to immediately. If you're changing the clutch ALWAYS replace the throw out bearing since you have the opportunity.
#17 | |
![]() ![]() Join Date: Nov 2007
P.
#18 |
Oops! Forgot that one Paul. And a brass one at that.
#19 | |
As for replacing throw out bearing and pilot bearing, with Darrin and Darrin 2 around, we are not too concerned of trans drop. Nonetheless, agree bearing replacement is a good idea especially when paying someone to work on the car. Last edited by secondchance; 12-16-2012 at 07:10 PM. |
#20 |
![]() Join Date: Jan 2009
Seems like an opportunity for someone to come up with a stronger solid metal fork. Or maybe the original could be strengthened by filling it in with an arc welder?
