#11 |
![]() ![]() Join Date: Aug 2005
#12 |
![]() Join Date: Aug 2012
Move to Maryland and put historic plates on and then don't worry about it.
Glad it all worked out, certainly a relief so now you can enjoy gobble gobble
#13 |
![]() Join Date: Feb 2009
Well, the only major mode to the motor was plenum and injector housing porting so I felt confident that the car would pass the sniffer test with my stock chip. Since my Stainless Works headers did not have air tubes, I had a concern about being failed on the visual inspection. I had to add a set of cats provided by Jagdapanzer that had an air tube nipple welded into them and I then ran make shift tubes back to my air pump. So in a nut shell, all I really did is added a better set of cats, some air tubing and my stock chip. I'll get into serious motor mod's once I get past that last test.
Rich
