11-01-2012 | #11 | ||
Re: The dreaded Red Xs
...you can usually get with in 2-ft/lbs. when the spec is less then 20-ft/lbs but--you have to put a pipe on the end of a ratchet to break the plugs loose. What am I missing?
11-01-2012 | #12 | |
I use anti-seize but VERY sparingly. I'd rather they be a bit tight than get too much and have the cats suffer. yah, and also #8 is in a location that's hard to get muscle onto.
11-01-2012 | #13 |
Re: The dreaded #8 plug, improved
I just remove the engine to change the plugs.
1994 #293 ZR-1 Stainless Works Long Tube Headers, B&B catback w/ X-Pipe, 18" Shelby Series One Wheels, SLP CAI. |
11-01-2012 | #14 |
11-03-2012 | #15 |
Much ado about nothing..is in the eye of the be-holder of the right tools, for sure.
I think the basic issue as the OP point alludes to is that many jobs go easier when you have the right tools, but when you do not, you have to make do. I'm thinking of all the jobs that the factory does without a sweat that we have complicated processes for...Timing the cams comes to mind. I couldn't tell you how THEY do it, but it probably doesn't involve a piston stop, dial gauge or other special tools I have to plug into the crank etc or cam... Well, you get the point.
Sam 1991 ZR-1 :salute: |
01-20-2013 | #16 |
There are four (five?) seven MM screws and two plugs on the cover inboard of the A/C evaporator. Just remove them and you will have enough room to not only remove the #8 plug, but the whole cam cover. Takes me five minutes to remove. You guys have fun with your funky ratchets and extensions, I will remove the access cover.
01-21-2013 | #17 |
Ah! You must have had an LT1 car at some time!! I swear...sometimes I'd like to find the person(s) that make chit so hard to get and give 'em $10 worth of nickle-sized knots n bruises!!
01-21-2013 | #18 | |
It DOES look easier than LT1 #8??? I crawled over top of the motor from the driver's side, to lock it in...
A laser guided smart wrench couldn't do it any better. Quote:
And GMC S vehicle 4.3 #3 ain't a picnic either - smoke & mirrors, seance, etc. WITHstanding............ |
01-21-2013 | #19 |
Agree w Hib on this. I use a 5/8" deep with 3 U joints attached. That snakes it into the plug well. Then a 1/2" drive breaker bar. Once loosened, I can finger turn plug. Once undone, put a telescoping magnet and pull plug out.
To install, I can put plug into rubber hose to screw it in, then reverse the removal process for final torquing. BTW, I use a thin film of oil on the thread to eliminate seizing of plug.
01-21-2013 | #20 |
HAHAH awesome techniques guys ... this thread will come in handy when I attempt my first #8 plug swap. Thanks for the pics and instructions ---
[SIGPIC][/SIGPIC] 01' Dodge Viper GTS 11' Ford Raptor 90' ZR-1 Corvette LPE #699 |
