Old 10-24-2012   #11
1990 quasar blue
Default Re: Fuel opinion and additives
Originally Posted by Corbusa View Post
I just use Amsoil .
But heres a copy from another corvette forum about VR1
http://forums.corvetteforum.com/c3-t...ht-it-was.html
Thanks for the link. I should have said vr1 synthetic. Check out this link. I believe it's the same guy from the old Corvette forum link you gave me. The zddp numbers look sound.
http://speedtalk.com/forum/viewtopic.php?f=1&t=31224
1990 ZR1 #2574
Medium Quasar Blue Metallic
1 of 19
Old 10-25-2012   #12
Hib Halverson
No one needs to put ZDDP "additives" in the oil of an LT5 engine.
There is so much BS on the Internet about ZDDP it's ridiculous.
Low levels of ZDP in engine oils is only an issue with flat tappet camshafts working pushrod operated valves, ie: pre-'86 Small-Block V8s.
The LT5 is an overhead cam engine and thus has far lower loads at the lobe/lifter interface and does not require any additional ZDP either from an "additive" or a special oil.
In fact, on the subject of ZDP additives, be careful, very careful, because, contrary to popular belief, with ZDP, it is bad to assume that "if some is good, more is better". You can get to a point with ZDP concentration in the oil that more ZDP will damage the engine. If you insist on "brewing" your own ZDP fortified engine oil, don't let ZDP concentration beyond the point that you have above 1600 ppm phosphate content in the oil.
If you want to know more about ZDP and engine oils in general, see:
http://www.corvetteactioncenter.com/.../#.UIiwG46ICdU
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 10-25-2012   #13
4CAM LT5
Appreciate all the "de-bunking", HH....!!
[SIGPIC][/SIGPIC][B][SIZE=4][FONT=Arial Black][COLOR=DimGray][COLOR=Red]1991 ZR-1 #318 -- SOLD 3/28/2013[/COLOR][/COLOR][/FONT][/SIZE][/B]
White / Red Leather / Bone Stock / Two Tops / Goodyear Eagle GS-D3's
[I][B]The "Past Collection"... [/B][/I]
2004 [COLOR=DimGray]MSG Coupe [/COLOR][I](Sold)[/I]
[I]1996 [COLOR=SlateGray]Collector Edition Convertible / LT4 [/COLOR](Sold)
1989 Triple Black Coupe (Sold)
1991 [COLOR=Blue]Quasar Blue Convertible [/COLOR](Sold)[/I]
4CAM LT5 is offline   Reply With Quote
Old 10-25-2012   #14
Hib, that was a very well researched and comprehensive article. As a former journalist I always have appreciated your excellent technical writing. There won't be any extra ZDP gong into my engine!-- Bob
Old 10-25-2012   #15
Of course you would expect that as a former journalist I would be able to spell "going"..... :-)
Old 10-25-2012   #16
mike100
I do have some Amsoil Z-Rod 10w-30, but I only mix in enough to duplicate zddp concentration in 1990's oil blends. Maybe 3 qts out of 8 to boost the modern formulation mobil1.
My goal is to not to overspend on the oil and to not get crazy with any additives that will coat down the catalysts and cause me grief during future emissions inspections.
Old 10-25-2012   #17
scottfab
scottfab's Avatar
This time of year I use STA-BIL fuel stabilizer.
I get it to 1/4 tank and put in what's necessary.
No need to preserve more that 1/4 tank.
Scott
Old 10-25-2012   #18
Hib Halverson
Dude...as a former journalist, you know none of us can spell.
Hib Halverson
Technical Writer
Old 10-26-2012   #19
SteelBlueZR1
Regarding recommendations on engine oils and ZDP contents, if you haven't read Marc Haibec's tech paper, you should check out:
http://www.zr1specialist.com/HAT%20W...5%20Engine.pdf
Old 10-26-2012   #20
I admit it does make me feel right at home
