#11 |
![]() Join Date: Jan 2009
and the light that goes on when you open the center console.
If it is out of adjustment .... kills battery. if it stays on when the lid is shut. This one I know ![]()
#12 |
![]() Join Date: Aug 2012
That light don't work, not sure whats up with that, I tried to change the bulb and that didnt help, I hooked a test light up to it and got nothing...such an insignificant thing I'll worry about it later, but it might be a related incident (or just a bad connection). Anyway, I got my notepad out and hopefully this weekend can recruit my brother (a fellow zr1 owner) to help me pinpoint my issue.
#13 | |
Based upon this response. Time to move onto -=Jeffs=- suggestion. Your brother can help you out during the fuse pulling multimeter process. GC
#14 |
![]() Join Date: Sep 2011
Mine does the same thing , It / mine is just as ghlkal said , I have both after market stereo and aftermarket alarm . I like both features so I keep it on a trickle charger..
#15 |
Mine will last about 2-3 weeks without a trickle charger.
Here is the manual page with the table of what things should draw what current. It requires the DVM be put inline with the battery as has already been suggested.
#16 | |
![]() Join Date: Feb 2006
amperes on a meter with 0.00 resolution. So it's safe to say that my stock ZR-1 draws less than 30 milliamperes at rest. I think the manual says less than 50 milliamperes, but that's from memory ...
#17 | |
![]() Join Date: Oct 2004
That's what he needed for a start and I believe everything that I've ever seen wanted less than 30Ma, 20Ma is great, FSM says "add circuits" and most electrical shops will accept less than 50Ma. Looking at the FSM information posted after checking the AMP I might go directly to the "HEADLAMP MODULE". If a headlamp has worn bushings and maybe doesn't complete the "park" I imagine that would likely be a substantial draw. Last edited by WVZR-1; 10-17-2012 at 02:03 PM. |
#18 | |
#19 |
I also just got online and ordered me a pair of bronze headlight gears...gonna fix that while im at it.
#20 | |
The gears aren't often needed but if you're in there why not. I'd only be concerned with the electrical diagnosis this time. Check the draw first before tampering with the head lamps. If you show "no draw" then I'd cycle the lamps before I did any thing else and when they don't park or stutter check the load again. Here's a link "DaveK" posted regarding the H/L repair: http://home.comcast.net/~zrjuan/headlight.html Last edited by WVZR-1; 10-17-2012 at 07:04 PM. |
