Old 10-13-2012   #11
secondchance
Default Re: DOES ANY ONE ELSE HAVE ONE LIKE THIS
I wouldn't put keys on painted gas doors-especially on dark colored Z. That's how you end up with scratches.
Old 10-14-2012   #12
bdw18_123
What the heck are we talking about here? That circle thing with the number stamped on it? What is it?
Old 10-14-2012   #13
efnfast
Having never seen one, my guess is it is the butterfly out of the secondary air runner.
Old 10-14-2012   #14
DDSLT5
Yes - secondary throttle body butterfly plate. Removing them gives zero increase in performance, loss of 2-4 mpg.
DDSLT5 is offline   Reply With Quote
Old 10-14-2012   #15
efnfast
Zero performance gain, simplified system. I'm ok with that. 2-4 mpg loss, that ain't great. Swollowing a screw (saw that here) also ain't great.
Old 10-14-2012   #16
Corbusa
Theres gotsta be a way to screw , loc tite & weld the screws so they wonts comes loose. I really like the power and hate to give up 2-4 mpg especially when the fuel cost goes to $7.00 a gallon..
Old 10-15-2012   #17
BOB HDZ
BOB HDZ's Avatar
Cool Re: DOES ANY ONE ELSE HAVE ONE LIKE THIS
I LIKE THE RELIABILITY OF REMOVING THEM!
BOB HDZ is offline   Reply With Quote
Old 10-15-2012   #18
mike100
I didn't realize you lost 2 mpg from a secondary-ectomy.
Old 10-15-2012   #19
scottfab
scottfab's Avatar
Yah, you'd think there'd be better economy.
I mean with all the weight reduction of all that
complicated stuff under the V.
I still like the idea of better long term maintenance
of things that follow the manual (where practical).
And knowing that if necessary I could swap out
the chip with a stock one when troubleshooting
unrelated things.
Not to mention being able to shut the valet key
off should I allow anyone else to drive it.
And then there's that question when a guest is in the
car, "what's the Full Power" light mean?"
Scott
Old 10-16-2012   #20
DDSLT5
Hi Mike,
The loss of economy comes from the swirl effect of a single runner feeding the cylinder (with the secondary closed that port feeds no air), allowing a more lean mixture yet still plenty of horsepower at steady cruise. Honda had a super efficient lean burn engine that employed cvcc technology "Compound Vortex Controlled Combustion" which is the same swirl effect. When that other secondary is opened all the time, this effect is lost, and some economy along with it.
My 415 with big cams, big valves, max porting still delivers 26 mpg with 3.73 in the rear - secondaries are retained!
