#11 |
Hopefully you will correct some of the errors in the 90-91 book.
#12 |
![]() Join Date: Dec 2005
Ya I know. We are working on it. If anyone has any input we are always updating the Judging manuals.
#13 |
Forgive me , I am a newbie to the Corvette world, is there a manual available to the owners to use as a reference for getting the car to Top Flight status? Even if mine is a 93 would the 92 manual get the car close?
#14 |
The NCRS is in the process of writing the 1992-1993 Judging manual. The two years will be covered in one manual. I think they are going to be ready next year. If you are interested in NCRS judging look at there web site www.ncrs.org. You must be a National Member and should join a Chapter to get the most benefit from the organization. Order a copy of the "Corvette Judging Reference Manual" and the "1990-1991 Corvette Technical Information Manual & Judging Guide". These two manuals will give you most of the info on the judging process. When the 1992-1993 manual comes out get a copy of it and the "1992-1993 Corvette Operations Manual & Preformance Verification Test Guide". I think the 92-93 judging will start in 2008.
#15 |
![]() Join Date: May 2006
Dave: Thanks for the kind words. I am hoping I can get to the National this summer in Boston and try for the Crossed Flags. See you there. Carl
#16 |
Carl, I'm also going to Boston for Crossed Flags judging. Good luck.
Dave |
#17 |
Dave i am looking forward to the show.
#18 |
![]() Join Date: Jun 2006
For those who may be submitting their 92-93 ZR-1's at an NCRS function, the first Flight judging meet will be in Leavenworth, Wa., in the middle of Sept., 07.
I had my 93 Ruby test judged in Las Vegas, the last part of April, 07. A lot of photos were taken and as a result the 92-93 judging manual is still a work in progress. I was advised I will receive the updated document prior to the meet in Wa. I received a 97.1 in the test judged phase. I can tell you the biggist hit I took was for 3 items. The air filter was 20 points, the battery was 35 points and the exhaust system was 20 points. That is a total of 75 judging points. By doing the math, that comes to a total deduction of 16 judging points. I have since replaced all the items with original equiptment except for the battery. You will not find a working AC Delco Freedom battery dated in 1993. So I replaced it with a current Delco and the deduction will be 20% of 35 points or 5 judging points. I calculate my total in this area will be 15 judging points, or a 98.6. What you are striving for is a score above 97.0 at a regional meet. Then the hard part starts. The next level is the Performance Verification test. Every working component must work the first time it is tested. I did a 1957, that had no major electronics, and it was very nerve wracking. The next and final level is you submit your corvette at a National Judging meet, and again score a 97.0 or better. I hope this helps those interested. I am still looking for the the grey foam air filter that goes with the engine compartment air pump, and the cloth, glove box item, that houses the two, wheel sockets. |
#19 | |
#20 | |
![]() Join Date: Dec 2003
