Old 10-02-2012   #11
Default Re: GCs HID Headlight Install PICs
what comes in the kit?
Two LP60 Glass Projector housings with HID Bulbs (You Specify Heat range/ color), Two Ballasts (I upgraded), All the factory connectors for the headlights with a Y Harness. Longer Headlight retention screws with inserts all stainless (You can see this in the pics). One Large piece of wire for the connection with side blade terminal connectors and instructions. The key to this kit is they use a Lexus/BMW projectors vs. folks using H4 Housings which dont work very well also its a Ture HI-Beam / LOW-Beam kit. GC
http://www.corvettehid.com/cart/inde...roducts_id=181
Old 10-02-2012   #12
scottfab
scottfab's Avatar
.... snip....
They truely are amazing and I consider them a safety item and well worth the bucks. GC
Safety items are good.
Looks like you could almost put two in each side.
Scott
Old 10-02-2012   #13
Yep I thought that too like the C6's however then you would double the Ballasts double the wiring etc. Not sure if all that would fit neatly in the bucket as the single does on side.
Old 02-03-2013   #14
GC,
Did u do the fogs also? If so, how hard is it on the 91-96 bumpers? How much access is required?
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 02-03-2013   #15
GC,
I did not however they are easy to access. On the 91 and up there are little access doors under the bumper for you to change the bulb. The ballast would fit on the back side of these doors. GC
